Old 05-02-2008, 03:54 PM   #1
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Static from Fan
Hi All
in my 2000 AUII i have a little problem. When i have the radio on (doesnt matter what station) i hear static through the speakers when the fan is on. It doesn't matter where the air is pointing, or if the aircon is on or off, it just has static. Turn the fan off - crystal clear radio. Does anyone know what might be the fix for this?
Thanks In Advance
Old 05-02-2008, 04:58 PM   #2
JMO
JMO's Avatar
I'd say a bad grounding of the radio. Pull it out and ground it elsewhere on unpainted metal, unless it's the stock radio, in which case you'd have to pull the ground wire from the harness and run your own from the ground wire hole in the harness to the new point. Might be wrong though, wait for a few more replies
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2008, 09:40 PM   #3
Mr Hardware
ok, ill have to try that. its only just started happening tho, i havent changed anything. stocko radio.
Old 06-02-2008, 02:00 AM   #4
JC
JC's Avatar
Yep - agree with this 100%.
If it turns out not to be the ground wire issue, then it is probably a broken solder connection inside the unit itself (and most likely on the earth circuit).
But I'd go with the poor earth first.
Ford Performance Club ACT
Old 06-02-2008, 01:22 PM   #5
Mr Hardware
hmm okay. i have another radio, i will replace it and see how i go. Im betting its something wrong with the fan unit under the dash though....
Old 15-02-2009, 04:11 PM   #6
Buddy 1
Buddy 1's Avatar
Originally Posted by Mr Hardware
Hi All
Thanks In Advance
Your an IT tech & you cannot work this out for yourself :P
Buddy 1 is offline   Reply With Quote Multi-Quote with this Post
