21-07-2007, 01:17 AM | #1 | ||
just browsing through carsales.com and this bloke with a nice ELfalcon says he has fitted an XF throttle body. I have seen them fitted to vl commodores/R31 skylines with the RB30 engine, but never heard of it on a e-series falcon?
Aren't the throttle bodies nearly the same size between the xf efi and e-series? http://www.carsales.com.au/used-cars...tial&R=1000051 cheers.... |
21-07-2007, 01:48 AM | #2 | |||
Must be running an after market ECU although he does run a chiptorque chip and the throttle cable linkage would have to change also. Seems like alot of work for such a little gain, since the stock throttle body can handle some big power figures.. cheers... |
21-07-2007, 11:03 AM | #3 | ||
Throttle cable/linkage wouldn't really impact on the ECU. You depress the accelerator, the throttle opens. You release the accelerator, the throttle closes. You could dodgy it up with a BMX brake cable & you'd get the same effect.
In the VL boys' case, their stock t/b is quite a bit smaller, and on a 3.0L. When you've got an FMIC that's larger than the windscreen and and a massive snail that could be confused for a kingswood cragar rim, the larger t/b from the XF would indeed have an impact on the RB30. As for our 4.0, the std t/b only needs to be 20% open to allow the engine to rev to 4000rpm or somewhere up there. An XF t/b might change that figure to 19% open. |
21-07-2007, 10:42 PM | #4 | ||
Formally ED I6
Visually they look the same size, only advantage I can see for a XF throttle body over an e-series is it has a constant circular section. However with the bends in the intake tubing and the bbm shape, I don't believe there would be any change in performance.
Daily driver 98' AU 349ci Fairmont Ghia on LPG --------------------------- Other 93' ED 5spd 4.0L NA Fairmont 13.75 @ 101mph |
