Soul baby
I just got sum clear front indicators for the ED and want to fit sum clear side repeaters, either the AU or BA ones. Ive noticed a lot of people around here have done that & I would like to know whats involved in making them fit correctly as they have different mounting styles.
People don't kill people, lawn mowers kill people. |
hibernating
you can fit au indicators fairly easily.. it just involves trimming it a little bit to make it fit in but its really easy. ba ones i guess shouldn't be too difficult to fit as well
Mr Forty Seven
There was a website that showed you how to do it, but I deleted the link not too long ago thinking I wouldn't need it anymore. But like neb says, you need to trim 2 of the 4 black clip holders off the plastic to fit the plug into the AU repeater. It's quite easy once you know what your doing.
EFII Fairmont Ghia Fully Optioned In White XR Kit, Engine & Springs. Leather & Sunroof Also Featuring NFERNO Registration Plates ELXR Front Bar & Bonnet with Sequential Scoop 18x8 Graphite Rims, Genie Extractors and Exhaust, Chrome Moulds ELGT Steering Wheel, Clear Repeators, Cornering Lamps, Tinted Windows Walnut Highlights, Pionner DEH-P9650MP Headunit & Pro-Series Speakers Local Playground: Brisbane CBD and surrounding suburbs |
AKA MYTE8
There's always that catch phrase...
" Once you know what your doing "
Its easy, I did it on the weekend with no instructions.
But AU1 ghia clear indicators and use your original globe. There are 4 soft rubber knobs which stick into the original lens. The new lens only needs 2 so cut 2 off. Then depending which way you want to face them you will need to trim the plastic door mould things to enlarge the hole. A stanley knife is all you need to do it.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
hibernating
yeah what dan said. if you want the part number for the au1 inndicators i can post it up when i get home tonight.
oh yeah "depending which way you want to face them" ... please face them forwards!! backwards looks weird. |
backwards for me!
hibernating
lol fix it dan!!
if they're backwards... i hope they cause too much drag when you're on boost and they pop out and then when you hit the brakes they bounce back in facing the right way ![]() |
Do I have to cut metal to fit them forwards? It looks like I do. Forwards is the skinny end facing forward yeah?
hibernating
yeah forwards is skinny end facing forwards... they look alot better facing forwards its worth the extra effort. you don't cut any metal. you just have to cut a little bit of the plastic guard so it fits in.. just cut away little bits until you can push it in hard and it clips in. if you push it hard enough it might just clip in forwards now... maybe
windsor user
if you trim a tiny bit of the actual indicator clip you dont have to trim the side mould
dan i have a pic of mine i'll send ya if you come on msn |
#12 | ||
ill post a pic up later of how i did mine, you guys make it sound hard! it took me a few minutes! i didnt trim any of the moulding either, only modified the indacator itself, and mines the right way around.
windsor user
just the same as me john:P
took me bout 2 mins each indicator ![]() |
#14 | ||
hibernating
actually i think i remember i trimmed the side mould then realised it wasnt doing much then trimmed the indicator and it worked lol
#15 | ||
To fit clear repeaters onto an EL i need the fairmont/fairlane moulds dont i??
#16 | |||
![]() ![]() ![]() I bought mine from a guy who used to post on the old FF site. PM Me if you'd like his contact details.
5 Speed EL Futura 140rwkw last dyno |
#17 | ||
well here's how i did mine, all i did was cut and file the large clip so it was basicly a flat peice of plastic then the tension holds it in. also you are better off using a EF-AU bulb holder as they dont leak and look better!
#18 | ||
windsor user
i left a little bit of the "hook" part on my clip, it actually holds the repeater to the metal of the guard.....they are verry hard to take out...
#19 | ||
GT4.
I did the ones on Jareds Car (oneredED)
F4Rk!? Whats this about filing and bulb holders!? I used gaffer tape to hold the bulb in, and jammed the repeater in with brute force! To easy!! ![]() I also told him to dip his bulbs in some clear orange paint :dr_Evil: ... Donno whether he did that yet! they do look good though the right way around, they suit the cars really well. Last edited by Danny; 12-01-2005 at 03:32 AM. |
#20 | ||
hibernating
mine is like waynes still has part of the hook part on the end and clips on to the metal guard bit
#21 | |||
Last warning
Haha, and good luck ;) They're a great addition, but damn hard to get :o
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#22 | ||
Soul baby
Thanks for the advice guys, I've had the car for two weeks now & it's got the clear indicators all fitted up & a set of 15 inch EB mags (I think they're the sports one's, I've seen them on many EB XR6's tho). Next week will be suspension, then a tidy up of the paint.
