Old 08-07-2024, 07:08 AM   #1
None-ya
Default Venting frustration
Why the F is it so hard to find a/1 70 CFM carby's (let alone 6),
No there was to spelling mistakes ( 70 . . . 700)
No I don't give a F about your holly that keeps surging
No I don't give a F about your VH bom*adore with its 355 stroker
" As above " Chev / Mopar
" "Holly vs quadujett ( can't remember how to spell it)
ARRRRRRRRRRGGGGGGGGGGGGGGHHHHHHHHHHH
( CAN ONE OF THE MOD INSERT THE EMOJI THINGY WHERE THE THING THROWS THE COMPUTER AGAINST THE WALL??)
All people have the right to stupedity but some people abuse the privilege
None-ya is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2024, 07:28 AM   #2
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
Default Re: Venting frustration
Side draft / Downdraft?
A bike carb might be an option for sidedraft. Twin barrel holley might be good for downdraft. Even 6 x stromberg. Weber DCOE/IDA will fit the bill but are a bit spendy
I assume you are fabricating the intake?
If you have moved past venting and are looking for ideas share some of the details about the application.
I love Holdens....
cs123 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2024, 08:54 AM   #3
None-ya
Have been trying to find 6 X single barrel side draft carby's for a while for a ITB sent with a ED 4L(1), ( time to confuse people) 7L(2). AMR500 supercharger is a small 500cc positive displacement super 500x6=3000cc/3L, 3L+4L=7L ( had to get a laugh) lol forget about that.
The intake so far is just a ed log manifold that's been 'hacked of' 5ish cm from the head with the plan of welding (getting someone else to) a flange onto each port to bolt the carby's to . . . .
Old 08-07-2024, 01:13 PM   #4
cs123
cs123's Avatar
This is just my thoughts
I don't think a PD blower is a great match for ITB setup. You will need to feed the blower into a common plenum, then through the ITB.
I don't think the ITB is a great match for the ford 6 either. You will be forever chasing your tail trying to tune it, especially in a boosted application. EFI might offer some more tune ability over carbs
I would go with the more tried and true setup of a blower to a standard intake manifold.
But if you're keen on that setup I would recommend bike carbs. Select one that has a throttle size around the size of your inlet diameter.
Worth visiting this guy's youtube as well. He did an ITB setup for a mini
https://www.youtube.com/c/makingformotorsport
Good luck!
I love Holdens....
