25-01-2023, 08:46 AM | #1 | ||
Peter Car
Just purchased some second hand G6/XR50 taillights for my G6ET, they are in pretty good condition except for some swirl marks in one, and some minor scratches in the other. I'm thinking that polishing them should get all the swirl marks out, and should go some way to make the scratches disappear, but not sure how to go about it.
What should I use, plastic polish? Ok to use a dual action orbital and a light cutting pad? Or would a normal light cut polish like S20 Black do the job? |
25-01-2023, 09:24 AM | #2 | |||
praek tih kl jo kr
Wet sand with 1200, 2000, cut and polish, then finish with a soft polish. |
3 users like this post: |
25-01-2023, 11:02 AM | #3 | ||
Couple of coats of UV clear coat for fading prevention, like polycarb headlights?
Cheers |
25-01-2023, 06:49 PM | #4 | ||
Experienced Member
When I restored some radio facias and some taillights/headlights, I used Autosol Metal Polish which gave me the desired result.
Autosol Metal Polish works well on acrylic plastics. |
25-01-2023, 07:18 PM | #5 | |||
Scholl S20 Black will be perfect for the job, start with a finishing pad and step it up if needed. Perfectly fine to use a dual action machine too. In this case, I am dealing with factory defect headlights, but the process is the same. I actually needed Sonax Cutmax on these. Typically, you would only polish headlights if absolutely needed, however taillights are different as they are not coated in the same way as headlights are, so you don't necessarily need to apply a UV protectant afterwards. I usually just apply something like NV Nova Jet or Carpro Reload. You can otherwise get a specific polymer sealant to treat headlights. https://www.detailstore.com.au/colle...nt-spray-236ml photo hosting service These kits are also worth looking at due to the specific sealant they have included - https://www.waxit.com.au/products/in...40102509609049
4 users like this post: |
27-01-2023, 12:49 PM | #6 | ||
Peter Car
I hit them with the s20 black on a da. Worked well. Didn’t completely remove it all, but unless you put your face right up against it none of the scratches are visible. Have to have the right angle of light too. Standing behind the car you don’t see any.
Good result. |
27-01-2023, 03:39 PM | #7 | |||
Sometimes you have to know when to stop, if the result looks good and you have to be selective in seeing the remaining marks, then why bother chasing it further. Coat them in your chosen LSP and chances are that fill, hide or reduce any remaining marks.
28-01-2023, 03:07 PM | #8 | |||
Peter Car
30-01-2023, 01:16 PM | #9 | ||
Peter Car
