Hi
I had to change the brake pads on my mk7 FiST the other day so I jacked the car up using the normal jack first and then used a trolley jack on the blue spots in the pic , was that a safe place ? car looks and drives fine just want to make sure if I need to again in the future its ok https://i.imgur.com/b3KWbS4.jpg |
From the workshop manual, it should only be jacked from the side points as per the attached.
WZ Jacking Points.doc Last edited by GTLEGEND; 04-11-2018 at 02:40 AM. |
#3 | |||
a shame there's no central spot it would make it so much easier |
Where did you put the jack stands? You mention the jack points
