Old 14-03-2006, 05:37 PM   #1
djmaker
Default 1996 ford ef falcon
Hi this is my first post on these forums and im looking at purchasing a 1996 ford ef falcon or even a 1994 model im looking at spending around $5grand for the car.
i just had a few questions should i consider this car for $5grand or so or is there something i can grab thats quicker and also how many kw do these cars produce roughly.
Thanx and hope to hear from you.
djmaker is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 05:45 PM   #2
uglybob
XRWANAB
uglybob's Avatar
spend the $$$ and get a fairmont! all the little luxuries, and you don't have to bother trying to fit them later ;)
best bet - an EFII Ghia - 3.45 LSD, XR6 engine, etc etc - all good ИИИИe! :evil3:
'95 EF MkII Futura: http://www.cardomain.com/ride/980413/1
uglybob is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 05:52 PM   #3
Jet-Star
I saw some where that they are only around the 98RwKw :( Couldn't confirm or denie it as I haven't seen a stock EF on a dyno.
Jet-Star is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 06:30 PM   #4
djmaker
scroll down to the bottom also a nother site that had the power rating was nrma that had 157kw as well???
http://www.uniquecarsandparts.com.au...ord_falcon.htm
Old 14-03-2006, 06:52 PM   #5
uglybob
XRWANAB
uglybob's Avatar
fwkw - 157
kw that actually came thru to the wheels - now, around 95-105 or so.
Old 14-03-2006, 06:59 PM   #6
djmaker
thats not very quick... for the weight of the car/fuel consumption....
Old 14-03-2006, 07:01 PM   #7
Jet-Star
Compared too?
Old 14-03-2006, 07:04 PM   #8
djmaker
ummm i saw 1993 MITSUBISHI GALANT HJ V6-24 2.0l 110kw????
Old 14-03-2006, 07:06 PM   #9
uglybob
XRWANAB
uglybob's Avatar
well buy the mitsi then! : but you're not comparing anything even close to similar - so how is that comparison valid? compare it to the stated power of a commodore, then you're comparing apples with apples.
Old 14-03-2006, 07:14 PM   #10
snypereb
[EBGLT]
snypereb's Avatar
Welcome aboard mate! $5000 should get you a decent e-series anywhere form EA-EL up to you want you want in the end and what you spend fairmonts are the ИИИИ though!!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 07:19 PM   #11
vegabass
BASS ON BOARD!
vegabass's Avatar
at the flywheel.
each dyno will give a different result, its the torque you should be interested in. Torque= power=
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 07:20 PM   #12
djmaker
i was simply stating the power rating of that car as i said not much power for the fuel consumption and some one said compared to? which i showed the mitsubishi i dont see how you could say its not in a similar group... just because its not a v6 thats a 3.8l like the commodores that eliminates it as part of the comparison??? and as you can see i put ??? after the mitsubishi to see if it is 110kw and if any one knows just as i posted the website about the ford and some one gave me a answer. Its not like i have anything agenst any car im not biased im just looking for info.
Old 14-03-2006, 07:54 PM   #13
djmaker
sorry i forgot to ask... which one of the fords have the most power stock... within my price range because all the websites giving me well off kw ratings??
Thanx
Old 14-03-2006, 07:58 PM   #14
sd1800
Your missing a main point mate. Sure that mitsu has 110kw. Have a look at the fords torque and at what rpm. I'm not sure on the figures exactly but i know the curve is rediculously good. And you will feel it when you drive. I find it hard not to get the wheels spinning accelerating at a medium pace out of a corner :the_finge
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 08:04 PM   #15
djmaker
i understand that as i said its not like i dont want a ford thats why im posting lmao... just want info on em...
Old 14-03-2006, 08:04 PM   #16
vegabass
BASS ON BOARD!
vegabass's Avatar
djmaker, if your looking for a falcon to drive get a stock GL, if your looking for a car to tinker and mod get a Fairmont or a XR these had luxuries like better seats, trip computers, nicer steering wheels, gear ratios, cruise controll and more power (my el had like 167kw stock at the flywheel)
a falcon engine is a large 4l and produces heaps of torque, a 2.5 v6 wont produce as much. dont buy a car based on KW's. as i said each dyno says something different. I would buy a car based on torque. Mine has just short of 450nm
Old 14-03-2006, 08:15 PM   #17
djmaker
well i plan on buying this car in a month or two and i will be moding it but i only got $5gs for the car... which limits me to what i can get and from the looks of it xr6 will be a far fetch and the fairmonts arnt that cheap either... so thats why i was looking at the ef?? As i said im not sure on the pricing of evrey single model of ford but for $5grand i pretty much saw a ИИИИ load of ef models...
Old 14-03-2006, 08:41 PM   #18
FRDXR6
FRDXR6's Avatar
110kW @ 6750rpm
179Nm @ 4000rpm
1320kg
1995 FORD FALCON EF GLi Sedan 4dr Auto 4sp 4.0i
157kW @ 4900rpm
357Nm @ 3000rpm
1541kg
Look at those figures the falcon would kill the galant.
The ford has 47kw more and double the amount of torque of the galant! It also makes peak power/torque much lower in the rev range!
If i was you i would be looking at manual ef futura.
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 08:41 PM   #19
vegabass
BASS ON BOARD!
vegabass's Avatar
there tuff cars, just make sure you get it checked by a mechanic, look for the usual smoke on start up or while driving, noises and so forth, otherwise you will love it. plus if you crash it your driving a tank not a coke can.
Old 14-03-2006, 08:57 PM   #20
LukeyBAXR6
BA XR6
G'day Mate,
I was looking last week and managed to find a good pick-up in a White 1995 EF Falcon Sedan, with very tidy inside, spoiler, alloy wheels and 199,000 KM's. So considering i payed 3,000 for mine, you should be able to get a nice buy.
Where are you by the way? (State) If you don't mind me asking..
Goodluck mate, nice to see have you aboard aswell, I'm new here aswell.
P.S Should have my EF by the weekend guys
Phantom BA XR6 Falcon
LukeyBAXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 09:16 PM   #21
djmaker
thats a nice buy mate... im in melbourne dandenong area... got any pics of your ride??? and please do tell how it drives when you pick yours up ....
btw did you find the car online or ????
Thanx
Old 14-03-2006, 09:25 PM   #22
LukeyBAXR6
BA XR6
www.tradingpost.com.au
That's where i found mine.
You've got others which are good like www.carsales.com.au and www.carsguide.com.au
I don't have any pics of my car on the computer, and they wouldn't upload off my phone :( i'll make sure i take lots of pics when i get it with the digital camera though ;)
Old 14-03-2006, 09:59 PM   #23
Jet-Star
I found an EF Fairmont in Melb for my parents when I bought thier car, One female owner its whole life, service books, 155Km's, With RW $4,900..Its really not that hard to find a bargin, this was only a couple of months ago and thier only going to get cheeper!
Old 14-03-2006, 10:10 PM   #24
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
leathal_leigh is selling a nice EF on 16s what state are u in?
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 10:30 PM   #25
LukeyBAXR6
BA XR6
He's in melbourne, dandenong area.
Old 14-03-2006, 11:18 PM   #26
djmaker
kewl thanx luke i have been looking heaps on www.carsales.com.au its been my center of attention for some time now heheheeh ... but yeah ill be sure to keep looking for that bargain.
Old 15-03-2006, 03:11 PM   #27
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
the book to my '94 ef says 157kw but im unsure weather this is measured at the flywheel or the treads...
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 03:19 PM   #28
havoc19
havoc19's Avatar
that would be at the fly wheel on the treads willprobably be about 100rwkw if ur lucky
havoc19 is offline   Reply With Quote Multi-Quote with this Post
