OK just leaving info I found out from a wrecker about swapping XR4 parts into a standard WP-WQ 5 door.
Would xr4 front and rear bumpers bolt up to the WQ?....Yes Would the XR4 sideskirts also fit (or is it a different length from guard to guard?)....no fit 3dr only Will XR4 rear disc swap over to the WQ drums?....yes Will XR4 REAR seats (back and seat) bolt into a 5 door?....no Will the 2.0L clean swap out with the 1.6L?.... yes if you have all the required parts Would the IB5 in my WQ bolt up to a 2.0L? Or is it an entirely different bell housing? Different bellhousing Are the clutch's the same?....No Are all other components like driveshafts the same between the models?... no Would XR4 front seats with airbags possibly work with the wiring I already have in mine (non airbag)....No Are the headliners the same size between 3 door and 5 door?....No And would the roof skirt airbags also possibly plug in?....No info to help somebody I hope Cheers! |
How about from WQ to xr4?
I want to put xr4 seats front into my wp lx 2004 manual Fiesta . Will it work ?
