Old 29-11-2016, 01:47 PM   #1
mikecool84
Default S1 5L into older project. ECU/BEM/key requirements???
Hi guys, sorry to have yet another ECU/BEM question but I dont think it's been covered, if it has I am sorry and please send me the link.
I have a 98 S1 Fairmont v8 and auto to go into a 1950's International pickup.
I have the engine, auto, ECU and short loom (eng to ECU)
Can I get this going with what I have?, if not what do I need?
Bear in mind the end use, I do not want to use the AU keys or instruments but I do have to use AU injection and ECU.
Thanks in advance.
Mike.
mikecool84 is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2016, 01:59 PM   #2
wodahs
wodahs's Avatar
Default Re: S1 5L into older project. ECU/BEM/key requirements???
think your question is how to put the engine in an older vehicle with out using the bem that relies on the key and ignition barrel , that sum it up ??
the you need a bypass unit
like
http://www.shiftkits.com.au/index.ph...&products_id=4
or is there more to your question
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2016, 02:18 PM   #3
mikecool84
Umm, nope that's all there is to my question!
Thanks for the superquick reply!!!
Anyone used one of these before?
Old 29-11-2016, 06:24 PM   #4
bernbo
I put one into my old mans xh ute who had a faulty BEM which is a common fault. It worked a treat, bypassing smart lock and allowed the car to start. It had been in their now for over 5 years without a problem.
bernbo is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2016, 01:29 PM   #5
mikecool84
Thanks Bernbo! Good to know it works and has for a while.
Anyone done a conversion/swap type situation using one of these? Keen to understand how if the AU engine harness is easily adapted to another entirely different vehicle.
Cheers.
Old 30-11-2016, 06:06 PM   #6
MrEL
Sick Puppy
MrEL's Avatar
Im running an AU 5.0 in my Nissan patrol.
You need some smarts to sort out the harness but it can be done.
Mine runs standalone on the factory ecu and harness.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2016, 06:43 PM   #7
mikecool84
thanks mate, did you use a smartlock bypass to do it? Any tips?
Old 30-11-2016, 08:42 PM   #8
MrEL
Sick Puppy
MrEL's Avatar
Nope i used a moates quarterhorse.
That way i could turn off security , convert the tune to manual from auto and have future tuning capability.
