Old 09-09-2016, 09:44 AM   #1
sailaway
sailaway's Avatar
Default This Dipstick has a Dipstick Question.
After the recent service and being told I had a small oil leak from the rear seal I thought I had better get into the habit of checking the oil more frequently.
Problem is with the one finger I would use on the dipstick it is pretty weak due to arthritis and found it difficult to pull it out.
Does the MC Dipstick require a turn to the left or right before removing?
Pete
Melbourne
2010 Ford Mondeo Zetec TDCi Diesel
Colour: Frozen White
sailaway is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2016, 10:08 AM   #2
ope126
ope126's Avatar
Default Re: This Dipstick has a Dipstick Question.
No, it is just quite hard to pull out (as you are experiencing)...
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2016, 10:32 AM   #3
NZ XR6
Make sure that there's some oil on the O-ring.
Sent from somewhere using Tapatalk
NZ XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2016, 10:57 AM   #4
sailaway
sailaway's Avatar
If I could get it out first.
It was only a few weeks ago it was in and out a number of times for the service.
Prior to that a mate who is super fit got it to pull out.
Bloody annoying as I am about to start a very long trip next Friday (Melb>Sydney>Bris>Melb) and want to keep and eye on oil usage. Very little I reckon but best be safe.
Thx
Pete
Melbourne
Old 09-09-2016, 03:01 PM   #5
NZ XR6
Sorry, I missed that! It's quite a tight fit on my car but comes out easily enough. Sounds like you may need someone to get it out for you again. It should come out more easily with some lube on the O-ring, but might also pay to check there's no damage. I expect that it's just a tight fit though.
My MB has a minor oil weep from around the rear seal, but it's been like that for at least 2 years. It doesn't use a measurable amount of oil between services.
Sent from my iPad using Tapatalk Pro
Old 09-09-2016, 05:41 PM   #6
rondeo
Maybe some coat hanger wire bent into a hook with a flattened loop for the hand would help if oiling doesn't. I've been using my middle finger as a lever against the engine cover.
Old 09-09-2016, 11:06 PM   #7
cobrin
Challenge Accepted!
cobrin's Avatar
screwdriver through the hole of the dipstick and use it as a Tbar handle?!?
mine also has a weep (form 130K to current 180K, it's too minor to warrant doing it but I do spray it clean to monitor it every service but it's still just a patch, Has never made it to the underbody cover so I'm not too concerned. It's a diesel it's almost par for the course. Just grateful there's no others.
Old 10-09-2016, 10:01 AM   #8
sailaway
sailaway's Avatar
Thanks everyone for your suggestions and will take on the suggestion to use some wire or a large screwdriver to release it.
Good to know the minor oil leak isn't such a concern.
Oops! Time to head for the airport to pick up my guests for local tours the next couple of days and the big one next week. ;-)
Pete
Melbourne
Old 10-09-2016, 01:30 PM   #9
rondeo
Or a short loop of rope.
Old 10-09-2016, 06:47 PM   #10
11ford11
ditto to this ,allows you to pull without squeezing ............tie your footy laces to it.....................
Old 10-09-2016, 07:38 PM   #11
dirty hands
Over Thinker
dirty hands's Avatar
try a tent peg ... bend it a bit for your best hand .to grip
. and use the hook bit through the top ring of the dipstick
picture of the part shows the 0 ring
https://www.alibaba.com/product-deta...330382796.html
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2016, 09:25 AM   #12
sailaway
sailaway's Avatar
Solved!
Simply unclip the panel around it allowing a better pull and then push it back on. (Takes 2 seconds)
On a more exciting front me, mate and the Mondy returned yesterday after completing a VIC > NSW > QLD > VIC of over 4,000klms without a single problem.
No oil used, no rattles and every tank of diesel delivering on average just over 1,200klms.
Due to Newell Hwy being blocked by floods near Forbes yesterday it saw us doing about a thousand klms to get home after leaving Dubbo in the morning.
Comfortable high speed driving using Cruise Control made our trip very easy and cannot speak highly enough of the car.
PS: It is just a few hundred klms off having 230,000 clicks on the clock.
Pete
Melbourne
