15-11-2005, 01:09 PM | #121 | ||
Okay, I've been trying to look for some new stylish car mats, and i'm still deciding. And I'm starting to think of getting genuine ones.
I'm really after a 3 piece setup, with the one piece for the rear to go over the driveline hump. TAUTVE T13002 A6 CARPET MAT SET, FRONT SET, (4 DR SED T-SERIES OR T-SERIES) TAUTVE T13002 B6L CARPET MAT SET, REAR SET, T-SERIES $73.50 TAUTVE T13002 B6S CARPET MAT SET, REAR SET, 4 DR SED, T-SERIES $56.50 Okay so I've got the fronts, and with the rear is the B6L one piece, and the B6S two seperate pieces. Or whats the difference between them. Do they come in one piece at all (I hope they do)? Or is the B6L for LWB, and B6S for SWB? If anyones after a picture of what they look like heres one: http://i10.ebayimg.com/02/i/05/16/1d/bf_1_b.JPG Can't find any of the rear, so I'm not sure whether they are seperate or the one piece.
15-11-2005, 04:30 PM | #122 | ||
not here much anymore
LG I'll tell you now that you have a very slim chance of being able to pick these up. The vast majority were ordered by dealers specifically for the cars they were made for, so not many will be left as spare parts, and for the rarer ones like T-Series Id say the chances of being able to get some NOS are extremely minimal.
See how you go, otherwise head into your local Autobarn and go to their floor mat selection. If its the same company that the mob up here use (I think it would be), you can actually custom order floor mats to be made, and they can do things like Tickford logos/Ford logos etc on them. I looked into it a while back when I still had the Falcon, and it may be a better/easier option than trying to track down genuine ford ones.
RAM 1500
15-11-2005, 04:36 PM | #123 | ||
Yeah I was going to get some plain ones, and get some custom work done, but I just dont think they'd be nearly as good as quality as these T-Series ones. And ones with a Ford logo patched onto them, look pretty unprofessionally. After exams, I'll check the availability of them, but I think your right my chances wont be that good, I'll need to get some plain ones, and edit them.
Change the black cotton edge to a grey/white edge, to match my trims, and get a nice small "FALCON" like on the BA boots, in grey in the corner of them.
15-11-2005, 05:12 PM | #124 | |||
RAM 1500
22-12-2005, 02:29 PM | #125 | ||
Adapt or perish...
Just wondering what the code would be for the tie down rails for the inside of ute tubs. I know they come in 4 pieces, two for the rear of the tub, two for the front.
Carless
22-12-2005, 02:45 PM | #126 | ||
I am after these as well
On the Ford website it shows AUC 19010 A for the entire kit I am presuming you mean this:
22-12-2005, 03:00 PM | #127 | ||
Adapt or perish...
Those are the ones.
Carless
11-01-2006, 12:29 PM | #128 | ||
Okay, fellas...
After this part number. The light, above the C-Pillar, is it? Thanks! P.S. Is it this: AU2 F31002 A1 PANEL PILLAR LIGHT GRAPHITE, RH, (FORTE WARM CHARCOAL OR FORTE GRAPHITE OR FUTURA WARM CHARCOAL OR FUTURA GRAPHITE OR XR GRAPHITE OR FAIRMONT GRAPHITE OR FAIRMONT WARM CHARCOAL OR GHIA WARM CHARCOAL OR GHIA GRAPHITE) $17.90 AU2 F31003 A1 PANEL PILLAR LIGHT GRAPHITE, LH, (FORTE WARM CHARCOAL OR FORTE GRAPHITE OR FUTURA GRAPHITE OR FUTURA WARM CHARCOAL OR XR WARM CHARCOAL OR FAIRMONT WARM CHARCOAL OR FAIRMONT GRAPHITE OR GHIA GRAPHITE OR GHIA WARM CHARCOAL) $17.90
11-01-2006, 12:47 PM | #129 | ||
^^ I think I found the wrong thing, lol
Also after the panic handle: ER F31406 A1 HANDLE ASSY ASSIST, LIGHT GRAPHITE $10.60 NL F434A14 A6 HANDLE ASSY, FAIRLANE/LTD $11.90 Is that it? The top one? ERF...?
11-01-2006, 08:53 PM | #130 | |||
Chairman & Administrator
It is - I'll get back to you on your other query shortly.
Russ Quote:
Observatio Facta Rotae
11-01-2006, 10:29 PM | #131 | ||
They appear to be no longer available. They are described as LAMP, Reading & Liftgate as it's the same unit that is on the rear door of the wagon.
Cheers Russ
11-01-2006, 11:16 PM | #132 | ||
You never fail to impress russ! Top bloke, thanks!
20-01-2006, 11:26 AM | #133 | ||
Russell
Can you give me a price for a gas sender unit for AUIII dedicated gas Part # AU 9305 AW, and what warranty they have. 1 garage siad 1 month, another said 12 months Normell
Every day above ground is a good day. Still Drinking & Driving, But Not At The Same Time |
20-01-2006, 09:02 PM | #134 | |||
Hi
Around the $140 mark - I would have thought that they carried the standard parts warranty but you'd need to check that with your local dealer. Cheers Russ Quote:
02-02-2006, 05:17 AM | #135 | ||
I have the price right here ... I have both of them.
I recently purchased it through Sinclair Ford. AUC 9305 BW Gauge Fuel - Suggested Price ($141.00) - Unit Price ($132.69) AUC 9305 AW Gauge Fuel - Suggested Price ($153.00) - Unit Price ($143.98) AW has a longer cable compared to the BW part (both are needed for the dedicated LPG utes) Hope this helps
02-02-2006, 06:52 AM | #136 | ||
Thanks Guys
mine was $168 + $60 for fitting. Best part was the 12 month warranty tho. They usually last only about 6 months. Normell
02-02-2006, 07:32 AM | #137 | ||
I found out that the parts were fairly straightforward to replace on the ute and managed it myself (under the guidance of a qualified LPG mechanic/fitter ... but i got him to replace my rear axle seal and bearing on the driver's side.
03-03-2006, 12:29 AM | #138 | ||
Oh Yeah!
russelw I got a t3 te50 interior in blaclk leather. Im wondering is there any ts50 stuff I can add like door spears or many parts missing over the ts50 interior wise?
TAU F20952 B WOODSPEAR DR RH, SPEAR FINISH - RAINDROPS, T-SERIES $89.30 TAU F20953 B WOODSPEAR DR LH, SPEAR FINISH - RAINDROPS, T-SERIES $89.30 Im guessing these are the door spears?
Oh no! Duffman can't breath! Oh, yeah! |
03-03-2006, 02:28 AM | #139 | ||
They are the door spears. But, the TE50 interior, does not have the screw holes there to hold the spear on. You can either make your own screw holes, or you can glue the spears on.
The other piece of T3 Gear, would be the Raindrops Auto Surround. Cheers
04-03-2006, 10:33 PM | #140 | |||
Cheers Russ
04-03-2006, 11:20 PM | #141 | ||
Russ.. you have done it again.. here are the ultimate shopping lists for AU interior upgrades.
Add some Bling to your interior T-Series interior trim pieces leather trim options for the AU trim options for the AU Fairmont & Ghia
05-03-2006, 10:12 AM | #142 | ||
So these items could be used on the ute:
These items are the small elbow pads on the door trim panels (unbolt from backside of the door trim????? TAU F24180 A6 ARMREST ASSY - FRONT DOOR, BLACK - ESCAINE SUEDE, RH, T-SERIES 75.24 TAU F24181 A6 ARMREST ASSY - FRONT DOOR, BLACK - ESCAINE SUEDE, LH, T-SERIES 72.60 Now all the PANEL - TRIM FRONT DOOR, T-SERIES items are the entire door panel including the fabric/leather insert behind the door handle???? Now I am interested in the ARMREST Assembies in Suede ... but I am thinking that it might be cheaper to get the door trim inserts reupholstered in leather from a trimmer than getting an entire new door card. Thanks for the listings though ... now at least I can get the armrest pads already in Escaine suede.
05-03-2006, 12:09 PM | #143 | ||
Oh Yeah!
I paid 2k for a full t3 interior was that a good price got it from ftg. Included centre console, door trims and all the seats with some plastics/carpets. Should be interesting to fit im thinking the only thing im missing is the leather handbrake.
05-03-2006, 12:31 PM | #144 | ||
I have the leather handbrake and boot sitting at home ... I just need to find the time to remove the driver's seat to swap it over.
09-03-2006, 12:25 AM | #145 | ||
Oh Yeah!
Hay russell, I checked the database but couldnt find any info. What im looking for is the floor mats that come out of the au3 t-series cars. The ones with the little T scetched into them. Are they still available and if so do you know how much.
Thanks
09-03-2006, 12:40 AM | #146 | |||
TAUTVE T13002 B6L CARPET MAT SET, REAR SET, T-SERIES 73.50 TAUTVE T13002 B6S CARPET MAT SET, REAR SET, 4 DR SED, T-SERIES 56.50 Cheers Russ
09-03-2006, 08:57 AM | #147 | ||
Oh Yeah!
Ouch those are some expensive carpets!
Im guessing the boot carpet is NLA
12-03-2006, 02:47 PM | #148 | ||
Ford Focus RS & FG F6
Hi Russell,
can i get price and part # for AU2 forte front seat belts. Cheers. |
12-03-2006, 05:47 PM | #149 | ||
Can't find any listings for the AU.
Here are the EF-EL ones: EF F611B08 A SEAT BELT FRONT RH, (4 DR SED (-) FAIRLANE/LTD OR 4 DR WAG) EF F611B09 A SEAT BELT FRONT LH, (4 DR SED (-) FAIRLANE/LTD OR 4 DR WAG) EF F611B68 B1 SEAT BELT REAR CTR, 4 DR SED, (-) LTD, LUNA MIST EF F611B72 A SEAT BELT ASSY, CENTRE, 4 DR WAG ... and here are the BA ones: BA F611B08 A1 SEAT BELT ASSY, WARM CHARCOAL, RH, WARM CHARCOAL $146.00 BA F611B08 A6 SEAT BELT ASSY, MID STONE, RH, STONE $146.00 BA F611B09 A1 SEAT BELT ASSY, WARM CHARCOAL, LH, И WITH PASS AIR BAG, WARM CHARCOAL $146.00 BA F611B09 A6 SEAT BELT ASSY, MID STONE, LH, WITH PASS AIR BAG, STONE $146.00 BA F611B10 A PLATE - MOUNTING, USE AS REQUIRED $14.10 BA F611B64 A1 SEAT BELT ASSY, WARM CHARCOAL, REAR, CENTRE, WARM CHARCOAL $62.40 BA F611B64 A6 SEAT BELT ASSY, WARM CHARCOAL, MID STONE, REAR, CENTRE, STONE $62.40 BA F611B68 A1 EAT BELT ASSY, WARM CHARCOAL, RH И REAR, RH & LH, WARM CHARCOAL $74.50 BA F611B68 A6 SEAT BELT ASSY, MID STONE, RH REAR, RH & LH, STONE $74.50 BA F611B72 A1 SEAT BELT ASSY, WARM CHARCOAL, REAR, CENTRE, WARM CHARCOAL $30.60 BA F611B72 A6 SEAT BELT ASSY, MID STONE, REAR, CENTRE, STONE $30.60
05-04-2006, 09:42 PM | #150 | ||
dye hard ford supporter
hi russell;
just wondering if the fog light button from a AU1 TS50 is still available. last year i saw a thread with the following info. thread contains a picture of the switch i am refering to in a TS50 belonging to 012 part no: AU2 15K218 A : SWITCH FOG LAMP, 4 DR SED, (-)XR : $61.90. i can no longer find the information on the parts data base, maybe its no longer available or i am not searching the correct way. any info on this switch would be greatly appreciated regards jason. |
