Bring on the lion...
Hey guys, finished converting my auto to a manual..... WHAT A JOB!!! i cant believe what a difference it makes in all round power!!!! all i need now is an LSD. Just one question tho if anyone knows. My thermo fans wont turn off. i found some info that says to bridge out two terminals of the plug that checks the oil temp in the auto with a resistor but they still wont turn off..... anyone know how to solve this problem?
any help would be gratefull.
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD 9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile XC Falcon project car underway...... |
@jas_23_
behind the front passenger headlight, in front of the airbox, in the engine bay, there will be 3 relays inside a black box, these control the thermo fans, perhaps you have a faulty relay(relay contacts may be stuck). when you open the black box it will look like there should be 4 relays but there will be only 3 as the Ef's came with 4 and EL's came with 3.
this is all i can think of that could be the problem. and good luck finding the problem. |
Smash the Boost
are u running the auto ECU? If so, from memory, the ECU isnt seeing a trans temp. indication and hence is defaulting to running the fans flat out in case things are boiling. Or its something else totally lol. Someone smart on here will post soon
oh and BTW can u tell me how u wired in your reverse lights? im about to do the same conversion to my EL but i also bought a manual xr6 ecu
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
#4 | |||
One of my brothers mates wired the reverse lights so i dont know exactly, ill see if i can find out for you.
