Old 11-08-2006, 09:03 PM   #1
hppsc
Default Difference between AU1, AU2, and AU3 I6 engines.
Hi guys
The base model AU engine, does anyone know what differences they had between the series?
I can pick up an AU1 engine to go into my ED, but i'm not sure whether there was anything better on an AU2 engine, etc.
Thanks
hppsc is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 09:09 PM   #2
Fairlane
V8 Powaah
Fairlane's Avatar
No difference at all, AFAIK.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 09:27 PM   #3
JC
Miami Pilot
JC's Avatar
As Fairlane said, no differences at all. They are all rated at 157fwkw and 357Nm torque.
Ford Performance Club ACT
Old 11-08-2006, 10:46 PM   #4
onfire
onfire's Avatar
With the said.. what are the differences in terms of weight? Between a standard au1, au2 & au3 Forte.
FOR SALE: 2 0 0 3 F A L C O N X R 8
http://www.fordforums.com.au/showthr...31#post5041431
onfire is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 11:13 PM   #5
Casper
Contributing Member
Casper's Avatar
I would assume AU2/3 is fractionally heavier due to better equipement, bigger brakes, laminated firewall etc. Effectively the difference is SFA though.
Older, wiser, poorer.
Old 11-08-2006, 11:37 PM   #6
onfire
onfire's Avatar
With all that said in terms of weight.. AUI i6 vs AUII i6 vs AUIII i6 - Im guessing the AUI is slightly quicker.
Old 11-08-2006, 11:38 PM   #7
Casper
Contributing Member
Casper's Avatar
I think the day the engine was made is probably going to be more of a factor than the series the AU is for ET's
Old 12-08-2006, 12:11 AM   #8
JC
Miami Pilot
JC's Avatar
If it is, it also takes longer to stop thanks to the toothpick brakes. So maybe down the 1/4, a stock AU1 would just pip an AU2 of similar spec (eg auto forte vs auto forte). But in a go to whoa, the series 2/3 will win every time.
Old 12-08-2006, 01:04 AM   #9
xr6 ausome
Low au
xr6 ausome's Avatar
Just upgrade the brakes and the s1 will win each time even go to whoa :hihi:
99 au xr6 8 inch dvd pacemaker extractors sport exh lowered
MELBOURNE VICTORY/WEST COAST EAGLES :Reverend:
xr6 ausome is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 01:10 AM   #10
EFFalcon
Last warning
EFFalcon's Avatar
or we could talk about the engines like first mentioned :P
the exhaust manifold head sheild on the AU2/3 is better then the AU1 :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 12-08-2006, 01:11 AM   #11
JC
Miami Pilot
JC's Avatar
Well, then the AU1 will be a little bit heavier with the larger brakes off the series 2, so maybe not. We are talking less than 0.1 second for 400m dash, between AU1 and AU2/3. So the weight of the driver will actually determine take-off and acceleration more than whether it's series 1 or 3.
Old 12-08-2006, 01:12 AM   #12
JC
Miami Pilot
JC's Avatar
the exhaust manifold heat shield on the AU2/3 is better then the AU1 :P
But if you fit extractors, who needs heat shield! :hihi:
Old 12-08-2006, 01:13 AM   #13
EFFalcon
Last warning
EFFalcon's Avatar
i'd still want a heat sheild :P
Old 12-08-2006, 01:18 AM   #14
JC
Miami Pilot
JC's Avatar
For the LPG converter - yes, you would. I forgot about that. i before e, except after c.
Old 12-08-2006, 01:24 AM   #15
EFFalcon
Last warning
EFFalcon's Avatar
my bad, even if i didnt have LPG, running a heatshield to keep engine bay temps down a tad can only be positive.
Old 12-08-2006, 02:24 AM   #16
LOWAU
___________
LOWAU's Avatar
Don't the series 2/3 have 0.5L more oil capacity? so it brings it to 5.5L total.
LOWAU is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 02:26 AM   #17
Perana
Perana's Avatar
My Dad's S2 only takes 5L of oil..
The coil packs are different aswell... no idea on anything internal though.
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 09:20 AM   #18
Casper
Contributing Member
Casper's Avatar
I agree, even with extractors the heat shield is very useful to keep under bonnet temps down (or HPC coating).
As for the engines etc. Effectively there is no differrence in performance at all. As JC said, the driver would make far more difference then the engine/weight. Hell, the one with the bodgy rear shock would probably be more of a difference then the model themselves.
Old 12-08-2006, 09:35 AM   #19
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
I put a series three engine into my series one car.
I needed to take the coil pack off the old engine, the throttle body off the old engine (plugs were different) There was also something about the engine mounts IIRC.
Too many turbo toys......
2009 FG F6 Nitro LPI LPG 290rwkw on LPG.
2005 BAMKII XR6 Turbo with LPG (ex HWP 255,000k's and counting)
Honda 2001 CR500E Road registered CR500
Honda 1985 CR500 (the one with the arm ripping power)
DT200r regoed Hack
Yamaha IT/YZ 465 Vinduro rocket
Imported IT465 and 490 back up bikes
VF1000R mid 80's racer built by HMR
Honda CR480 Air cooled project road cafe racer.
T88 Turbo XT Falcon project with 351 Cleveland (mothballed)
Plus the rest.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 09:35 AM   #20
AUIIIXR8
Formerly AU2XLSV8
AUIIIXR8's Avatar
AU3 XLS ended up getting the XR6 non VCT motors. I've got one
Sadly the added weight of the ute take away any advantage there would have been however small the advantage was.
Current ride = Mazda 6 MPS
Toy = AU2XLSV8 - another one
(really my best mates but I'm claiming it)
Past
EL 6 S/C - sold
AUII XLS V8 Stroker - sold
99' Laser (runabout) - sold
BA Fairmont - sold
AU III XR8 220 - sold (so should have kept this one)
AU III XLS Tickford 6 - sold
Formerly AU2XLSV8
AUIIIXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 10:31 AM   #21
cArSiK
IIRC the VCT motor had some updates in the S2 release with the compression being raised a tad. Nothing official was released to say this. Casper is the man to confirm / deny this..
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 12:29 PM   #22
ned
Once shy... twice bitten
ned's Avatar
Can you identify what series motor you have from the writing that's cast on the front? Can anyone confirm the different number for AUI, AUII and AUIII ?
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11.
ned is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 12:35 PM   #23
bodes-sh
the writing on the head doesn't necessarily mean its from that engine, your best bet is probably the engine number...unless you know what car it actually came from
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2015, 12:15 PM   #24
Rfordsfun
Default Re: Difference between AU1, AU2, and AU3 I6 engines.
Hi all, my au2 fair/ghia has the heavy duty mounts, i think they are refered to as ef/au v8 mounts, but mines an i6 vct. Have to swap the passenger side out, it clunks with gear changes (auto) with no torque. are there any variations of this mount ? or are my current ones flogged as they sit very low compared to the new ( 2nd hand ef/auv8 according to wreckers ) ? cheers
Rfordsfun is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2015, 08:07 PM   #25
colinford
Ford Forum Members please answer a ? I have PLEASE , Will a Tickford Head of a EF XR6 Series 2 fit a 2002 AU 6cyl , as I have Headers & exhaust to suit
colinford is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2015, 09:05 PM   #26
Rfordsfun
Hi Colin, what exactly do you have ? And what are you trying to do?
