ANOTHER FORD DRIVER
Is there any way to see if the subs are still working i heard that a battery works to find out what speaker what could this way work with subs
any please matt |
#2 | |||
i heard something like that but im not sure apparrently you hook the + terminal of the battery up to the + termainal on the speaker and - on the battery up to - on speaker and it will sort of make the speaker move in or out depending on which way you connect it, u think its actually to check if you have a melted voice coil though |
#3 | |||
Low and Loud
You can "pop" a speaker to find out if it works by creating a "popper" Get a C size battery and soilder on a wire on each side of the battery, a Popper. This will make the speakers "crack" for a second so you can hear the speaker working or find the speaker when trying to locate the wiring. This isnt enough voltage to come even close to damaging the speaker. Not sure if it works on subwoofers as I normally just hook them to a amp to see if they work.
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
Low and Loud
Oh and when you have to solder the wires onto each side of the battery PLEASE be quick. if your not experienced with soildering DO NOT attempt this. Get someone who can do to this
ANOTHER FORD DRIVER
Is there anyway to see if my subs are blowen
matt |
ANOTHER FORD DRIVER
I had another look at the subs today still not working. I though that the amp might be stuff but it check out fine as the power light was on. I plug a speaker into the amp i had nothing. I have had the cd player out for a while and it look like some tape i put around some wire has melt abit could this have any thing to do with? I'm also thing audio cable the red and white cables that plug into the amp and back of the cd player. Can anyone help that has the same type of problem .
any help would be great as i'm going insane. matt |
