Fairlane
Hi all,
I went to change my boot struts in the Fairlane and the ball mount snapped of from corrosion. I have a new ball mount but now I cant remove the old one because it just spins when I try to remove it. (rusted to the nut) anyone know how to sort this? Thanks,
Ford and Jeep.... both four letter words ![]() 2006 TS Territory AWD 2016 Everest Trend 4WD |
CNC fixer guy
Might have to drill it out while someone holds the ball mount with pliers.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
Fairlane
yes I had this in mind but installing the new one will be a challenge
CNC fixer guy
Can you attach a pic or 2?
Fairlane
I drilled an inspection hole to see what was happening at the nut end. Trying to upload pictures but not letting me. says upload failed.
Ford and Jeep.... both four letter words ![]() 2006 TS Territory AWD 2016 Everest Trend 4WD Last edited by Fairlane63; 13-04-2016 at 09:27 PM. |
You will probably looking at a clean up of parent metal in the area, anyway, so perhaps a side cutter after you have shielded areas around the area.
Then clean up, weld new ball mount into position and repaint. Alternatively, and depending on whether any spare length in your strut, abandon the first hole and start afresh in an adjacent spot.
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension -- ----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 ----- -------- Preventative Maintenance Policy -------- |
RIP...
Can you get an angle grinder in?
. Oval Everywhere... |
There is a product called Rost-Off (no not Rust-Off) made by Wurth that dissolves rust in a jiffy. Its 20 times better than say WD40. If you can get that to the nut end it will come apart easily.
Saying that, I didn't know there was a nut on the back end but am guessing you know because you have a new part ?
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
#9 | |||
Fairlane
Fairlane
CNC fixer guy
I would say the nut is spot welded to the sheet metal.
If you cant re use the nut then perhaps clean up the rust and treat it and repaint then get a longer ball mount and drill the old nut a tad bigger then place a new nut behind the old one. If the rust is too bad in the boot channel perhaps a stainless washer under the ball mount?
#12 | |||
Fairlane
#13 | ||
I need to do mine before it gets real bad. Where did you get a new one from?
#14 | ||
Fairlane
EBAY mate. I think $19
#15 | ||
Got a link? Couldn't find one for a falcon.
#16 | ||
Fairlane
#17 | ||
Do you reckon mine would be the same ?
![]() ![]() I'm guessing AU and BA would be identical ? |
#18 | |||
Fairlane
I am guessing so mate. they sure get ugly don't they!
#19 | ||
This was mine.
![]() I cleaned it up and was able to slip a nut in behind ![]() ![]() ![]() The ball was from a BA
BUILD AU II FAIRMONT GHIA HERS AU II Fairmont Ghia 7" DVD/GPS Radio 19" Wheels HIS FG XR8 Ute Lux Pack Tech Pack Touch Screen GPS |
#20 | |||
Fairlane
That is interesting. I may be able to cut a slot in the body mount big enough to put a nut in behind once I grind the old one out. Hmmmm..
#21 | ||
CNC fixer guy
Might want to invest in a dremel type grinder to get in the tight spots.
#22 | ||
Fairlane
That my friend is good advice. thank you.
#23 | ||
what size nut ?
#24 | ||
CNC fixer guy
As a matter of interest, do you know if the car has been or is usually parked on an angle (nose down) where water can collect near the hinge?
Ps. Get some rust treatment and gal primer etc happening.
#25 | ||
nope
Underground parking all it's life But yeah rust treatment first then get that nut |
#26 | |||
T-Series Club Member Vic
They are different to the AU boot strut so don't expect to find a nut on yours. Will work well once you get the old one out though ![]() Hope you get it sorted! |
#27 | |||
Fairlane
looks a bit how ya goin but in the scheme of things is hardly noticeable unless you know what you are looking for.
#28 | |||
CNC fixer guy
Another hole but at least it will stop the boot lid falling and putting holes in your head. Just get rid of the metal filings, fill the old hole and treat the rust before it gets worse.
#29 | ||
Fairlane
yep.
it's amazing how much better it is with two new struts. they sure do a good job holding that dead weight! It used to slam shut with gravity but now you have a task to pull the boot down. very nice!
#30 | ||
CNC fixer guy
I had a good look at my strut mounts today and found minor surface rust so i flooded it with rust converter.
Hopefully that slows it down. The problem is water can intrude into the unpainted section that's welded on.
