Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
Hello,
What kit would you recommend applying to a 94 ED XR8 Sprint? I have the standard disc and pad setup at the moment and believe I really have two options; 1 - Upgrade the discs to something slotted or cross drilled and put better pads on - obviously the cheaper exercise or 2 - Get a new front and rear brake kit. What do you have that would fit and what sort of ballpark figure would I be looking at for price in this option (including the calipers, discs and pads). Do you do 2 and 4 piston kits? Cheers, Matt |
Ive been checking this post for a reply everyday, interested to see what there is other than the ebay spec twin pbr fronts for the e-series
Eb Xr8 Ba Xt mk2 daily |
#3 | |||
Race Brakes Sydney
The first option is the cheapest for sure and allround with pads would start from about $900. The second option we have two front upgrades but no rears. 1.2 piston with 330mm rotors and no offset change - from $2200 2.4 piston AP Racing caliper on two piece 343mm rotors - from $4200
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
Thanks Matt, appreciate the quote!
#5 | |||
Race Brakes Sydney
MATTHEW PEARCE
I'm just wondering what size rims are needed for these brakes.
Thankyou |
Is it also available for a E series models, XR's
Race Brakes Sydney
We do the kit for EA EB ED EF and EL. The ED and earlier models have a different ABS ring though and can prove difficult to get.
MATTHEW PEARCE
Thankyou, but what rim size is a minimum requirement i.e 17 inch
specifically the AP racing brakes
#11 | |||
Race Brakes Sydney
AP Racing calipers fitted to these vehicles require a larger 355mm disc or even bigger so there is enough room for clearance and to make the bracket as there is no room when going smaller rotor sizes on multi piston calipers but we have done a 6 piston wilwood under 17" wheels i think a 330mm disc as the wilwood caliper is smaller bodied.
Twin piston caliper with 330mm discs is 17" but 18" or larger for the bigger kits.
MATTHEW PEARCE
