Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
19-06-2013, 10:23 AM | #1 | ||
Hello,
Just wondering if there is a way of searching thanked posts and filtering down to the ones i have thanked?
Build Thread: BA XR8 with all the goodies. fordforums.com.au/showthread.php?t=11247663 |
19-06-2013, 08:18 PM | #2 | ||
Chairman & Administrator
If you click on the search button in the top navigation bar (the one that has UserCP, Gallery, Broachures etc.) the drop down menu gives you the option to find all thanked posts but there isn't any filtering although it looks as if there should be.
Cheers Russ
Observatio Facta Rotae
19-06-2013, 08:34 PM | #3 | ||
Further to that, I have just noted a setting in the thanks system that allows the following:
Show a user's post thanks stats in their profile. These stats come along with links to search all posts that user gave thanks to and all posts of his/hers that got thanked by someone else. I have turned on this option but I think it won't populate the data until the overnight cron jobs are run. Cheers Russ
22-06-2013, 09:04 PM | #4 | ||
Thanks Russ. Much appreciated
22-06-2013, 09:13 PM | #5 | |||
24-06-2013, 07:46 AM | #6 | ||
I can't either so I think that I need to modify the member profile template to display that information. Might be a project for next weekend.
Cheers Russ
24-06-2013, 09:23 PM | #7 | ||
I've won half the battle - there is now a link on the member profile page to find all of their posts that have been thanked. The counter (x thanks in y posts) isn't working so I'll have to work out why. It does work when I enable the stats box bit then it repeats a whole pile of other stats as well so I'd rather not use that!
Cheers Russ
4 users like this post: |
24-06-2013, 10:30 PM | #8 | ||
Many thanks for the EPIC job you do Russ
25-06-2013, 08:18 PM | #9 | ||
Ok, it's fixed by embedding part of the stats block inside the block I was using. Looks a little ugly in terms of sizing but I can fix that later (I think) - if you go the member profile page and look in the FORUM INFO block then underneath Total Posts you will see the thanked post stats along with a couple of others. If you don't see the box then expand the Statistics drop down to display them.
Cheers Russ
2 users like this post: |
25-06-2013, 08:38 PM | #10 | ||
Awesome
Location: In my own little world..Everyone here knows me :)
Nice one Russ
