This is probably a really stupid question.
We have a basic el cheapo LPG mixer system on our AU3. As per normal they have simply wedged the venturi ring into the air intake pipe, but unfortunately it has gotten lose over time and keeps moving. It will flop over and then doesn’t work. Is there anything I can use to glue it in place, that either will NEVER come lose, or if it does won’t **** things up when it gets sucked into the engine?
Time to Make the Hippies Cry Again |
Chairman & Administrator
Something like the Araldite ultra clear or the 3M Weldmate plastics glues should be fine - both provide a solid bond with little residue to get sucked into the intake if they come apart.
Cheers Russ
Observatio Facta Rotae
