Any ideas guys
One of my coil packs spark is only coming out of 3/4 of outputs Is this unusual? Are the Super Cheap generic brand coil packs any good? If not what is the best brand to buy. Should I replace both? Cheers |
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
How did you determine only 3 out of 4 were sparking ? If they are the originals it would be time to replace MSD or VDO are pretty good options check E bay they list a few at reasonable prices and yes Both would be a good idea
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Spark only came out of 3 of them whilst holding the lead out of them, then tried to earth the fourth one but still no spark
#4 | ||||
Back to Le Frenchy
Replace with MSD is the usual option, part# MSD8241.
Q - CAR
AU FORD STROKER 347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned. |
T-Series Club Member Vic
I'd first try swapping out that lead as it sounds like you were still trying to use the same lead to see the spark between the coil and the lead. If the lead is shot the coil isn't going to be able to push a spark through air to a lead that is too shagged to help it get that spark to earth...
Yell out if you need help, I'm in Melbourne's south-east and have 2 spare leads (the long ones!) and coils. |
