27-02-2013, 10:17 PM | #1 | ||
Hey guys,
Just picked up au unregistered 2002 AU XR6 Manual (first of this series). Doing my best to get it licensed so I can use it as my daily driver. I have a few issues that need rectifying, one of them being the side indicators. It appears someone has come by and stolen the side indicators, and in doing so, they have cut the bulb holder off. Is there a clever way to get in so I can extend the wiring and put new bulb holders on? The wiring left isnt enough for me to attach a new connector, and the hole in the side of the gaurd isnt big enough for me to work inside of. Any info would be much appreciated. Thanks,
1993 ED Falcon 2.5" Full Exhaust System Lovells Low Springs all round 2002 AU XR6 Manual, current project 2004 BF Fairmont Stock - family car |
27-02-2013, 11:56 PM | #2 | ||
just take the front guard of to get to the wiring its about 6 bolts i believe and just pulls off easy as! Take of front bar first tho
28-02-2013, 01:16 AM | #3 | ||
Cruising...
Yup take the guard off, when i had to pull a guard off, i didnt remove the bumper, just the grille and headlight as per thread http://fordforums.com.au/showthread.php?t=11371310
Once its off youll hopefully have enough wiring to wire another indicator up. here's a pic of mine.
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 |
28-02-2013, 01:35 AM | #4 | ||
Cheers for that, there appears to be enough wiring for this to work perfectly. I'm assuming its a little different with the XR headlights? too dark to have a look right now, in your experience will I have to remove more to get the gaurd off?
28-02-2013, 01:42 AM | #5 | ||
Cruising...
Oh crap, thats right..yours is an XR.. sorry, times getting on haha. Uhm yes, there is more to it, you will have to take the whole bumper off then. How, unsure, standard bumpers have two bolts, one on each side corner of the bumper, so undo that then all the scrivets, the stone tray, then indicators and it should come off i think.
Been a while since i did that write up, dont remember exactly if you could undo the inner splash guard liner in the wheel arch to access things as an alternative to removing the front bumper.
02-03-2013, 05:41 PM | #6 | ||
5.6L x 2 pilot
Have you got enough wire in the blinker recess to strip a bit of the insulation? If so, you should be able to get a soldering iron to it to lengthen it. Then just slide a bit of heatshrink down to insulate the join.
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
02-03-2013, 08:02 PM | #7 | ||
DFDFDF
You might also be able to just remove the inner guard plastic and get access that way depending on how much cable you got left in there..
Cheers, Nik
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
09-03-2013, 07:25 PM | #8 | ||
After a few niggles (previous owner had lock nuts on wheels but no lock nut key) finally got this sorted today. Managed to pry the splash gaurd back and pull the wiring out as Roosta said.
Cheers for the help guys.
