01-03-2013, 08:22 PM | #1 | ||
Has a blue one
Tonight I replaced a blown fuse for the stop lights. When I turned the ignition back on a loud beep came from the dash and since then the car no longer starts. Could I have accidentally triggered the smart shield to thinking I'm trying to steal the car?.......The smartshield hand flashes ninety to the dozen when i try to start her
I have dash lights and radio, but absolutely nothing else. Is it curable?
If we call for the proof and we question the answers, only the doubt will grow. |
01-03-2013, 10:05 PM | #2 | ||
check the engine fuses in the engine bay worth a shot
01-03-2013, 11:20 PM | #3 | ||
no longer starts, does that mean cranks but won`t start or is just plain dead.
02-03-2013, 07:39 AM | #4 | ||
Has a blue one
Cranked twice, now it's dead except for dash lights and radio
02-03-2013, 11:50 AM | #5 | ||
5.6L x 2 pilot
Check your key, make sure the transponder has not dropped out of the handle end. Do you have a spare to try?
Stu
02-03-2013, 12:42 PM | #6 | ||
Next upgraded Mk1 Leopard
Thats what happened to me
UK
02-03-2013, 06:21 PM | #7 | ||
probably unrelated and a stupid question, but how is your battery, got plenty of charge?
02-03-2013, 07:55 PM | #8 | ||
Has a blue one
I'm starting to think the fuse to the smartshield may have been removed while the ignition was still on.............Any chance that may have created the problem?
04-03-2013, 08:16 PM | #9 | ||
Has a blue one
Thanks for all the suggestion all. The car is now back up and running.
It was the dome light causing the issue
