Old 03-03-2013, 09:37 AM   #1
RegSpec
RegSpec's Avatar
Default Speed and toll cameras?.....
How do they work?
How do they tell the difference between a car and truck or a vehicle with multiple axles?.....
I know they have height sensors to apply the higher toll to trucks but Ive always been curious about the multiple axle difference?...
06' BF XR6T manual sedan in Bionic Blue.....written off 08/15......greatly missed...
New ride....07' RSpec manual Typhoon in Winter White....factory sunroof, Premium sound, Process West intercooler, upsized tubing, valve springs, 1000cc injectors, Delphi intank pump,*modified turbo, 4" dump, 5" cat, dual 2 1/2" Xforce exhaust, Mal Wood Opt 5 clutch, Herrod shifter, Ozrace coilovers with adj. Whiteline bars, 6 spot Brembos,
Edit by Crescent Motorsport.....382rwkws @ 1150nms on E85....
RegSpec is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2013, 09:59 AM   #2
cobramania
FPV BFII GT Cobra No.249
cobramania's Avatar
Default Re: Speed and toll cameras?.....
In NSW, toll cameras & fixed speed cameras have multiple electronic sensors in the road surface (same as Traffic Lights). They are spaced specific distances apart & as you go over them, the timing between each sensor triggering, lets them know how many axles a vehicle has & how fast you are traveling (fixed speed cameras in NSW don't use radar anymore, they now trigger from electronic sensors in the road surface, almost impossible to fool, less chance of errors in readings & can also tell which lane a speeding vehicle is in, even if there's vehicles traveling along side each other).
The distance between axles only varies a minor amount for each vehicle type, & the space between axles is much greater & easily defined between a car, car with trailer, light truck (pantec), bus, semi-trailer, B-double, etc.
The heavy vehicle cameras, take video evidence, & a computer looks at the footage & using mathematical calculations, can seek out & find the vehicle dimensions much the same as face recognition on your still or video camera.
cobramania is offline   Reply With Quote Multi-Quote with this Post
