04-02-2013, 09:19 PM | #1 | ||
The 'Stihl' Man
OK so I got a call that my partner who went to pick up a trailer from a hire place and that all of our tail lights have gone out.
Im talking RHS/LHS, spoiler light and the one in the rear glass! So I first thought fuses, I pulled the ones related to the tail lights out all are in tact, no singe marks or anything like that. Also pulled out the larger fuse/relay on the LHS (I cant recall its number..its half the size of the flasher) and that shows no sign of failure. I pulled the RHS tail light out, checked the bulbs. Filaments are fine and the "park" light works on both the LHS and RHS...so I believe the bulbs themselves are fine. What does that leave me with? The only thing I can think of is maybe the brake light switch although from my 10+ years of Falcon ownership Ive never had a problem with them...how can I test it?
04-02-2013, 09:36 PM | #2 | ||
Hi. The brake light switch is a common fault on all falcons from EB to AU. If you haven't had one fail in 10 years you are doing well. Testing it is easy using a test light, just turn on the key and probe both terminals on the switch and one of them will make the light come on then probe the other terminal and at the same time hold down the brake pedal, if the light comes on the switch is OK and if the light does not come on the switch is faulty. The other way to test the wiring and globes is to link the terminals on the wires and with the key on the brake lamps should work. Cheer MD
04-02-2013, 11:01 PM | #3 | ||
Just cruisin'
My guess would be brake light switch. I have had problems with EF/EL in the past, and have been informed AU are the same lol.
06-02-2013, 05:27 PM | #4 | ||
5.6L x 2 pilot
Also, be wary, a fuse can be blown, but look ok. Test it with another fuse of the same value.
Just a thought Stu
06-02-2013, 05:40 PM | #5 | ||
Just cruisin'
Our AU had an issue with the brake lights the other day too, kept blowing the fuse instantly. Was earthing out in the tail light globe socket. Required a replacement socket.
06-02-2013, 09:29 PM | #6 | ||
AU II XR8
Ok, so is it just the break lights that aren't working, or is the break lights and tail lights? Any problems with the head lights or park lights? Answer these and I'll point you in the right direction.
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
06-02-2013, 09:31 PM | #7 | ||
5.6L x 2 pilot
Brake lights.
06-02-2013, 09:50 PM | #8 | |||
Just cruisin'
He says the park lights are fine. I think he's been pointed in the right direction to fix his brake lights too |
06-02-2013, 10:02 PM | #9 | ||
The 'Stihl' Man
Hey guys..sorry for the late reply.
It was most certainly the brake switch, so thanks for the tips. It just seems a large coincidence that it occurred when a trailer hire place was rigging up a trailer..hmm..better not happen again as I am going back friday. Cheers!
07-02-2013, 09:18 PM | #10 | ||
Hi. Finding out that your lights are not working is a lot harder now days. People drive round in their own little comfort zone with air conditioning, sound systems and phones and then ignore someone in the car beside them trying to tell them that they have a problem, no one comes out to fill your car with petrol any more and do you even see you neighbours much more than once a month. Even with a car that can tell if you have a blown bulb, if a switch fails it still wont tell you as it doesn't know that you are braking. Cheers MD
