#1 | |||
Hey guys, I'm looking at moving onto my next project once the Falcon is on the road and I've been eying off a particular car which an easy engine conversion can be done, problem is:
Project car was built in 2003, new engine is from 2001-2002 but from the same series of car. New engine is 2L, old engine is 1.8L. Power from the new engine is 127KW, power from factory engine was 91KW. Only optional in Japan, wasn't offered here in Australia (But there was a 2L engine offered in Australia, different engine though). Now, the new engine in question actually has the same block, just different internals and head to the factory engine, so there is no need to modify anything structural for getting the engine into the car, even all the accessories fit on, same with gearbox, sensors, ECU, loom etc. Looking at VicRoad's website we have three options here: Quote:
Option 3, does it still need to be engineered? Thanks much guys, this is a bit of a HF. |
Just use your block that way everything matches.
No need to change anything. |
Nothin is simple even when you just ring to ask a simple question, they put you through to about 3 or 4 different departments to still be no clearer after an hour on the phone,
Bennyk351 XW GS, 461 ci Windsor, C10, 9inch |
I think if you read further or maybe on a previous page of the regs you will find that it applies to engine changes without any engineering required. Under the national code of practice it is ok to increase engine capacity and or power by up to 20% without engineering requirements.
http://www.fordforums.com.au/showthr...sic+xp+cruiser |
What about if the engine is older than the car?
as long as its same model , year wont be an issue.
whats the engine code for the 2 engines ?? I have swapped boss 290's where 220's have come out and required an engineers. but i have also converted Nissan Patrols from 3ltr diesel to 4.2 diesel and havnt had any issues with vic roads. |
#8 | |||
Or model names? FP-DE is the factory engine, FS-ZE is the replacement I'm looking at. |
#9 | |||
I emailed VicRoads, got a reply saying my email has been marked for response, so lets see what they say.
#11 | |||
BANNED
Option 3 says it needs a VASS report. To my mind that means a VASS engineer needs to sign off on it. I've tried to have sensible conversations with the VASS guys...good luck trying to find one interested or having the specialty you require. You can only use the guys that are on the VicRoads list. I am in Geelong and the closest is Tomkin Consultants in Adelaide. He wanted to be flown down to inspect the vehicle and his daily $$$ rate paid. |
