#31 | ||
Hopefully the build quality improves, the clips on the trim are in most cases stronger the plastic it is holding in, you can easily snap trims, stress mark them or snap off the clip from the trim without much force with a trim removal tool. I worked on two new VE sportwagons this week, had to pull out a lot of trims to hide wires under.
We also noticed the factory battery terminals are loose from factory, you can move them by hand, or you can very easily bend the crap out of the terminal using a 13mm socket to try undo the top nut to add any accessories as the nut is tighter than the terminals which makes them spin, catch on the battery bracket, if you try lever off that the terminal deforms. Maybe that is why they seem to have a lot of electrical problems? |
#32 | ||
Flairs - Truckers Delight
They'll keep the LWB. Makes no sense to axe it from the aust market when it's the basis of the Caprice PPV in the US.
#33 | ||
Peter Car
#34 | ||
Straight Eight
They're the same trim level, but with more power. I don't think it counts.
The Falcon is dead. Long live the Mighty Falcon. |
#35 | ||
Oo\===/oO
More or less engine options really.
#37 | ||
im startled that no one has mentioned that if this was an article about falcon itd be all doom an gloom about holden struggling and commadore was colapsing and all the ussual rubbish
#38 | |||
Straight Eight
Welcome to FordBashingForums.
#39 | ||
What I meant was they will only have one caprice variant... They will definitely keep lwb... My guess is it will get a nose job.
#40 | ||
Regulator
I think it's a good thing to consolidate models and have fewer.
Ford should do the same and drop the XT in favour of the G6.
Regards Bobby Current Cars: 2000 AU2 Fairmont (2019-current) 2003 BA1 Falcon Divvy Van (2017-current) 2009 VW Mk6 Golf 118TSi (2020-current) Previous Cars: 2003 MCX10R Avalon VXi (2017-2020) 1995 EF1 Falcon GLi (2016-2019) 1997 XH2 Falcon Van OPT20 (2016-2019) 2006 BF Fairlane Ghia (2013-2018) 2001 AU3 Futura (2010-2013) 1996 EL Fairmont (2008-2010) 2004 BA XR6 (2005-2008) 2001 AU2 Forte (2005-2006) 1988 EA Fairmont Ghia (2003-2005) 1984 AR Telstar TX5 Ghia (2001-2005) |
