Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
Think Heavy..
G'day would just like to get an idea on prices and brake kits
to suit an 07 BFII XR8 please? Need to try work out what i can and can't spend. A kit like this (http://www.pbrperformance.com.au/performance.htm) seems like a good start, i do occasional track work, fyi. Much appreciate any help in advance. Cheers Mick.
________________________________________ 07 BF MkII BOSS 260 XR8 6spd manual! EGO ![]() There's no replacement for displacement!!! ![]() Handling: Bilstein Shocks with King springs all round, Whiteline 27mm front swaybar & 22mm rear adj, upgraded PBR rotors, calipers and braided lines all round with Bendix Ultimate pads. Go Fast Bits: Herrod C.A.I with K&N 4" pod flter, Herrod Helix spacer, Herrod oil breathers, Tridon 72c thermostat, Herrod 2.5" stainless cat back zorst. |
#2 | ||||
Think Heavy..
Just found this in one of your older threads
Pretty sure my fronts are 322mm and rears are 328mm.
I'm still wondering if you might be able to re-engineer this kit to take for example a VE V6 caliper which would be a lot easier to get hold of than a PBR C5. Fits over a 30 mm disc so perhaps with slightly thinner pads would work on a 32 mm disc too? Probably not as good as the C5 caliper, but still a big improvement on BF brakes and helpful to all those people who don't want to buy new wheels. I'd probably buy a kit like this if you could get it together for a reasonable price :-)
#4 | |||
Race Brakes Sydney
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
#5 | |||
Race Brakes Sydney
Yes we can do the 2 piston 355mm front and a rear 328mm upgrade thanks.
MATTHEW PEARCE
Think Heavy..
edit. Mispost
#7 | |||
Think Heavy..
#8 | |||
Race Brakes Sydney
The front calipers are RED but would you want powder coated red rear calipers as well or we can do the kit cheaper if we supply plain ones and you paint them? Slotted rotors are supplied in the kit with braided lines.
MATTHEW PEARCE
Think Heavy..
Unpainted would be fine, as i'd like to keep the blue theme. Do the new Calipers bolt onto the standard mounts? Is the kit on the pbr site what i will be getting? Appreciate the help.
#10 | |||
Race Brakes Sydney
MATTHEW PEARCE
Race Brakes Sydney
Brackets are supplied with the front kit but not needed for the rear is there any chance you can PM me and also check your rear brakes as the 328mm you said you may have generally was only on the series 1 but if you do have it then you will only need a front kit. You can also check the rear disc by the thickness or look at the disc and see if there is venting in the centre of the disc thickness.
MATTHEW PEARCE
#12 | ||
Think Heavy..
Rear rotors are solid, definitely would like to upgrade front and rear as my rotors are shagged and i'm pretty sure my calipers won't withstand too many more track days.
Also, does the kit come with braided lines?
________________________________________ 07 BF MkII BOSS 260 XR8 6spd manual! EGO ![]() There's no replacement for displacement!!! ![]() Handling: Bilstein Shocks with King springs all round, Whiteline 27mm front swaybar & 22mm rear adj, upgraded PBR rotors, calipers and braided lines all round with Bendix Ultimate pads. Go Fast Bits: Herrod C.A.I with K&N 4" pod flter, Herrod Helix spacer, Herrod oil breathers, Tridon 72c thermostat, Herrod 2.5" stainless cat back zorst. Last edited by Bunyip04; 04-07-2012 at 07:14 PM. |
