hey guys i want to put thermos in my eb, do you guys just put ef/el ones in. also how do yous hook them up i was just thinking of hooking one side onto the fuel pump relay and the other side on a switch.
any help would be great cheers scott
'93' EB fairmont 5 speed manual. extractors, high flow cat, 2.5 inch sports exhaust. Freshly painted in Cobalt Blue. lowered with ultra lows. 17 inch mags fitted. Just finished putting a low km el motor in her |
i think its just a matter of riping the clutch fan and slide the thermos in, but i'm not sure
lol ^^ If you don't know then why post ? It's not a matter of just riping the clutch fan out and putting thermos in, if it was then what would power them ?
Bakes - there is a guide on how to do this mod on www.e-series.com.au I think Neb wrote it. That should explain everything you need to know. |
thanx damo i will try find it.
#5 | |||
Missing the boost :(
BA XR6 Turbo
301rwkw mild tune ![]() Modified by XR6Turbo Developments |
Posts: n/a
Yeah, like cruzin'dickwad'eb said, just rip the clutch fan out, and slide the thermo's in.
Oh, and while you're at it, you also need a temp sensor, then a thermal switch to turn the thermo's on when the coolant gets to a certain temp. I haven't done the mod, but i know roughly what's required. I'm sure someone who's done the mod will be more than happy to explain in depth. |
#8 | |||
Where can i get a temp/thermal sensor from im just about to do the this weak end but im useing au thermos
Yeah Rite
u can get the thermo switch from super crap or anuwhere. thats where i got mine from.
i used EL thermos they bolt straight in to my EB radiator. ive been told that EF ones are variable speed controlled by the ECU. so they may not work with a thermoswitch
EB2 143rwkw...goone now riding in MX5 with a little hairdryer on the side of the engine |
Lovin the Manual.
they all work.
even au ones and yeah get one of them universal thermo switches from autobahn with the little copper bit u tweak into your top radiator hose. then use that to earth the power to the thermo fans when it gets to the desired temp (like 96deg or somethin) |
#12 | ||
[EBGLT]
Do you have to have the sensors?
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
#13 | |||
![]() Join Date: Aug 2005
