So...
How often do you top up your coolant fluid and what do you use? |
Since I replaced mine some 12 months ago, I've not had occasion to add any more at all...hence I don't recall what I used!
Cheers |
90 tectaloy plus and whenever it needs it maybe every couple months.
Falcon Unbelievable!
Aluminium radiator with Nulon Red every 12 months usually flush it in spring.
Never top mine up as I have no leaks i drain and flush once a year using ford premix with demineralised water (I have a mate in the local ford parts who looks after me
[SIGPIC][/SIGPIC]
RIP...
I never top up, but change every few years with this and tap water.
http://www.nulon.com.au/products/Coo...ms/Ultra_Cool/ . ![]()
. Oval Everywhere... |
Flairs - Truckers Delight
I use nulon anti-freeze/anti-boil (plus inhibitor) long life coolant. I haven't had to add any in over a year. I don't ever do a 'flush' - a part of the cooling system will fail forcing a change soon enough. This goes for just about everyone.
#8 | |||
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
No topups, but use coolant conditioner from Natrad (has no antifreeze as I am informed this is the corrosive part on seals, hoses etc).
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
#10 | |||
#11 | |||
RIP...
I've never had a need for glycol (anti freeze/boil) and it's associated corrosion producing properties. Even in snow conditions. Most people don't.
We have to top up a small amount every 3 months, but we don't have to add much though, maybe 1/2 a litre every 3 months? From the service history apparently there's a weap at the water pump, but since it's not using to much we haven't done anything about that one yet.
![]() (No idea if it's 1/2 a litre, basically it'll go near the min mark every 3 months or a bit longer, then I top it back up to the max mark). My mechanic puts in Nulon long-life coolant, I usually top up with demin water though. I was told it's normal for these cars to use a bit of coolant though? I'm surprised to here everyone here saying they never need to top up! Last edited by webbiegareth; 02-04-2012 at 11:26 AM. |
#13 | |||
RIP...
If the coolant needs topping up every so often, there's a leak.
#14 | ||
My AU series one
5 litres every week it leaks around the water pump and the metal line close by I use Supercheap $5 for 5 litres stuff once a week ive also had the argument about pre 84 cars but when it runs out that fast who cares its been like that for 5 years with no issues thanks John |
#15 | ||
Critical Thinker
I have never needed to top up. I forgot what coolant was used when I have my cooling system flushed and radiator done. But if I was to, I would use De-mineralized water just to top up.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
#16 | ||
Never, I was going through a little bit a while ago due to a leaking bottom hose; however since I changed the hose no leaks. I flushed the system a few weeks ago, and use Nulon's long life concentrate mixxed with a bit of distilled water.
#17 | ||
Topped up my AU2 TE50 once every 6 months (very very slow leak from thermostat housing when hot).
Never needed to top up my AU1 TS50 - never leaked. Always use Motocraft premix + distiller water in my AU2 and Tectaloy + distiller water in my AU1. Never use tap water in any of my cars. |
#18 | ||
Auto Nerd
I never top up the coolant, unless there is a leak. I have only ever found leaks where the heater hoses go into the cylinder block and at the back of the water pump.
What I do every service is check the pH of the coolant with a multimeter. If it is too acidic, I will flush out the system and start again. |
#19 | ||
I put new coolant in every 2 years or engine change..... Whichever comes first.... :p
#20 | |||
#21 | |||
Critical Thinker
