Old 24-01-2009, 09:52 PM   #1
lost focus
Default focus instument cluster problems
We have a 2003 focus with a problem with the instrument cluster... regularly drops out.
Research on the net shows this is obviously a widely known problem. Does anyone know if Ford Aust are accepting any responsibility by way of recall or subsidy for fixing the problem?
Thanks
lost focus is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2009, 12:09 AM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
None whatsoever I believe. I have the same problem but haven't asked the question directly.
The best fix I have hear of is to remove the instrument cluster and spray the back of it with WD40 or similar, and allow to dry.
I believe the problem is caused by something called dry solders
Old 25-01-2009, 02:32 AM   #3
Mullett
Badly Focused
Mullett's Avatar
Oh, dry solder...if that's the case, pull the cluster out, take it to an electrical repair place (like TV repairers for example) and ask them to re-solder the joints. I doubt it'd cost much, maybe $50 max? And you'll never have the problem again. WD40 won't do much except keep moisture off, and make it a to work on if you do need to get it re-soldered.
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2009, 02:42 PM   #4
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Quote: "take it to an electrical repair place and ask them to re-solder the joints."
As some of you may be aware my '03 LR LX's instrument cluster has strange things going on with warning lights flickering. I've got another theory on why it's failed......another common failure is the Cowl. A small amount of water got in through the cowl and the screen so MAYBE this has caused the joints to get wet and hence the failure. Just a theory. I'll make enquiries with my local guy and see what they think. Beats shelling out over $1K for an Instrument Cluster if it fixes the problem.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2012, 08:37 PM   #5
Kevinvk2ce
Default Re: focus instument cluster problems
I have a 2003 Focus and have similar problems with my instrument cluster. Two Ford dealers could not find anything wrong and suggested sendin it to Evertec in Sydney to have it repaired. I replaced the unit with a second hand one with the same part number. The PC board on the old one had several burnouts on it so it is not repairable anyway.
My problem now is the replacement cluster has the ABS and red brake warning lights permanently lit because the car does not have ABS, it's a 2 litre auto hatch CL basic model.
My question is can the new cluster be reprogrammed to tell the cluster that the car does not have ABS?
I did a search of this Forum and couldn't find an answer to my question.
Kevinvk2ce is offline   Reply With Quote Multi-Quote with this Post
