Gentleman,
Who here can make me some piping from the airbox outlet to the throttle body on an FG XR6 n/a? I want to get rid of the combustion chambers and have a wider diamater pipe, that still houses the air flow meter. Thought I'd post it here to get the most traffic, PM me if your interested. Will pay $$
FG MK 2 XR6 Turbo Sedan - Auto PW Stage 1 Intercooler Plazmaman Piping Plazmaman Turbo Side Intake Hybrid turbo - GTX3582r 61.3mm 11 blade billet wheel - 38mm porting and wastegate flapper - 11psi turbosmart actuator Venom high flow cat and cat pipe Middle muffler delete 3.46 Differential Ratio ID1000 Injectors Walboro 460 intank 360rwkw @ 16psi 12.17 @ 118mph with valve float on old tune and 18psi with a crap turbo and a 66mm wheel |
Peter Car
Getting rid of the combustion chambers? Air flow meter on an Fg?
Someones got some serious wires crossed here. Any exhaust shop should be able to bend some pipe up to do the job, then get it polished. |
Not the airflow meter, hence the "that still houses the air flow meter". Just remove the combustion chambers.
Aside from having 'crossed wires', do you have any reasoning for not removing them? They just seem to obstruct airflow.
#4 | |||
LIFELONG DJR SUPPORTER
Your combustion chambers are your cylinders, you sort of need them.
you do not have an air flow meter
ROCKING THE EL FUTURA
how do you remove combustion chambers in the motor, dont you sorta need them...?
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
I think op is a bit confused or really likes typos hah
2001 Falcon Fairmont AU2 Big turbo coming Lsd |
Op do you mean resonance (spelling?) chamber?
#9 | |||
Peter Car
Thanks to all those who were obviously born experts for their contributions. Clearly none of them had to learn by making the odd mistake in terminology - or more likely they didn't have the Internet to witness it.
Russ
Mustang GT mmmmmm......
As we all like to be helpful at FF, here is a link to a do it yourself guide for the installaltion you seem to be describing.
http://www.fordforums.com.au/showthr...ght=ba+air+box
I have become a Mustanger. |
#12 | ||
Haha, oops... I feel very silly now!
Thanks XRtowcar for that DIY ![]()
