Old 15-01-2012, 07:51 PM   #1
imbhvn
Default au series 3 poor fuel economy
Okay so ive had the car for around 17 months, ever since ive owned it its had really crap fuel economy getting roughly 300 ks to a tank. it now gets around 400 ks to a tank, parts that have been rwplaced are as follows, new oxy sensor, new tps, leads and plugs, new fuel filter, new oil and filter, new air filter, new fuel pressure reg, gutted cat and cleaned throttle body. im getting over having to fuel up on a regular bassis and want this problem fixed! i just tested the tps in ohms and volts, ohms test came back good, volts came back as throttle close 0.40 volts, throttle fully open 4.00 volts, from what ive read thats seems to be good. I checked thermostat just now which has 113 stamped 113 degrees? Au are meant to run a 92 degree thermostat correct? will running a higher temp thermostat cause it to guzzle fuel?
Any help/info you guys have will be greatly appreciated
imbhvn is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2012, 07:59 PM   #2
imbhvn
Default Re: au series 3 poor fuel economy
Just realised the thermostat is a 92 degree one
Old 15-01-2012, 08:00 PM   #3
nstg8a
3..2..1..
nstg8a's Avatar
what sort of driving do you do? all city, all highway, mixture of both etc
on a bad run i get 400-450 from mine, a good run il get 500+, 90% city driving.
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2012, 08:40 PM   #4
imbhvn
I put 40 dollars in ( roughly 29 litres) last night and drove to phillip island and back 220 ks and i had 10 ks till empty its 100 kmh all the way pretty much. Pretty poor if you ask me.
Old 15-01-2012, 08:41 PM   #5
imbhvn
The absolute most ive gotten to a tank is 450 and thats hwy driving
Old 15-01-2012, 08:42 PM   #6
nstg8a
3..2..1..
nstg8a's Avatar
cant really measure it like that though, you need to fill it right up, then reset the trip meter and see how many total kays your getting.
Old 15-01-2012, 08:50 PM   #7
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Around Syndey, all city, I use to get about 350k's out of a full tank on Petrol.
500 on the highway full load (family of 5)
UK
Old 15-01-2012, 08:51 PM   #8
imbhvn
Yeah ive done that. on average i get 350-400 to an over filled tank.
Old 15-01-2012, 08:54 PM   #9
imbhvn
Did you find the problem?
Old 15-01-2012, 08:54 PM   #10
FOCUSonTHIS
FOCUSonTHIS's Avatar
I do a mix of freeway and city driving I get about 500km to a tank. If i do all freeway driving I can get a max of 800km to a tank
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 15-01-2012, 09:02 PM   #11
imbhvn
Id be happy with that
Old 15-01-2012, 09:13 PM   #12
Uncle_Ken
Uncle_Ken's Avatar
No I just got LPG and now I get 330 aorund town but onl y pay $30 a fill
UK
Old 15-01-2012, 09:16 PM   #13
imbhvn
Haha well thats an easier way of fixing the problem.
Old 15-01-2012, 09:20 PM   #14
wildXR8ute
try changing the MAP sensor, i had a similar prob with my efXR6
wildXR8ute is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2012, 09:50 PM   #15
imbhvn
If the map sensor was shagged wouldnt it run ****/blow smoke?
