hi all i am looking for the type of cars and models that had a 5speed manual tranny that would go into a ke laser
if anyone has any infvo please reply to this thread or email me directly on rjo71342@hotmail.com or use that email to contact on msn messenger |
What a performer!
G'day mate.
KE (non turbo) Lasers use the F series gearbox. Alloy. Not very strong, but the KE's did not need a strong box as the engines are weak as ****. If you need a replacement gearbox you can pick them up very cheap. The KE turbo's with the DOHC engine come out with the G series gearbox. Steel. Much stronger. They WILL bolt directly in. However are not cheap. The G series gearbox's from the KF/KH DOHC's will also fit with small mods needed. Basically if you need a strong gearbox get a G series gearbox from a FWD Turbo KC or KE Laser TX3. Expect to pay $600 minimum to $900 maximum. You will need a decent clutch and fly wheel to suit. Rob |
vippin
thanks for the help it was appricated i found one but do not know what series it was from but they r slugging me 350 include change over thanks again mate |
#4 | |||
What a performer!
Old enough to know better
I've seen a few tranny's around Kings Cross, if that helps.
(Sorry, that was a really bad joke, but............................I just couldn't resist)
