12-02-2011, 02:16 PM | #1 | ||
Next upgraded Mk1 Leopard
As a happy owner of a new high series cluster (see this thread
http://www.fordforums.com.au/showthread.php?t=11319816 ) Now every time I start the car it sounds Beep Beep Beep... What is it warning me off? Sounds like DTE alarm. UK
12-02-2011, 03:23 PM | #2 | ||
Barra Turbo > V8
IIRC its a seat belt reminder, correct me if im wrong.
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
12-02-2011, 03:26 PM | #3 | ||
Audi S3
no beeps on my High Series cluster... no idea?
12-02-2011, 03:33 PM | #4 | |||
Barra Turbo > V8
12-02-2011, 04:12 PM | #5 | ||
I get a beep on my Xr6 cluster when my DTE is below 80, 40 or 20km when i start my car.
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| |
12-02-2011, 04:16 PM | #6 | ||
Are you starting the car with the door open?
12-02-2011, 04:21 PM | #7 | ||
Not starting with door open, I can't see the DTE flash in the cluster like I did when the low series.
UK
12-02-2011, 10:09 PM | #8 | ||
In my experience with my S2 Fairmont6:
Door position during engine start will not activate any warnings... With the DTE less than 80 km, yes the beeping will sound a series of three beeps, about six or so times...in this instance, on the screen, only the accompanying text will flash, not the actual number... with you sitting in the car without the seatbelt fastened, there are no audio warnings... There's nothing else I can think of at the moment! Cheers |
12-02-2011, 10:16 PM | #9 | ||
Alternator
an open door DOES activate a warning but the beep is slightly different to the low fuel one you get at DTE 80, 40 and 20
ive never had one for a seatbelt before and i would have definitely noticed one as i always reverse out my drive and dont put my seatbelt on till after i finish reversing i have noticed my cluster beep weird at me once before after i had pulled it out and plugged it back in messing around with some things and i think it wasnt functioning right somehow minor from memory but it was a fair while ago now so im not 100% i know i just pulled it out again and took out the plugs and then put them back in and it worked fine after that? cant help you more than that sorry |
12-02-2011, 10:31 PM | #10 | |||
Audi S3
12-02-2011, 11:24 PM | #11 | |||
13-02-2011, 10:44 AM | #12 | |||
I have a 1999 fairmont, and ive put the blue Xr6 cluster in it. Now the DTE is on the cluster in front of me, not on the climate control one.
13-02-2011, 12:51 PM | #13 | ||
I might put the 'low' bback in and check the settings.
UK
13-02-2011, 03:32 PM | #14 | ||
What level is the petrol gauge at? If it's around 1/4 tank, I'd say it's DTE.
13-02-2011, 06:58 PM | #15 | |||
Walking with God
On the high series, doesn't the DTE warning come on the Climate Control area with the other fuel, km warnings etc? If so, then doesn't that explain why you can't see the DTE on the cluster? GK
13-02-2011, 07:49 PM | #16 | ||
adrian
any you have to clear it or it goes on for ever, unlike the XR that stops after a little while
T3 TS50 #17 275kW AU3 XR8 SVP 220kW |
13-02-2011, 09:54 PM | #17 | |||
It goes beep beep beep 12 times thne stops. UK
13-02-2011, 10:16 PM | #18 | |||
Walking with God
GK
13-02-2011, 10:41 PM | #19 | |||
Wil put some go gas in tomorrow. How much? UK
13-02-2011, 11:54 PM | #20 | |||
Walking with God
3/4 or more on an interstate run, then run it back down to the 1/2 way mark, with injector cleaner. GK
14-02-2011, 02:10 AM | #21 | ||
It's morphing into a Plymouth Roadrunner "beep beep".
regards Blue |
14-02-2011, 09:26 AM | #22 | ||
VFII SS UTE
oil pressure??
hand brake on while moving?? overspeed?? door ajar?? seatbelt?? low fuel??
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
14-02-2011, 09:47 AM | #23 | ||
the one no has mentioned air bag.if the air bag light is not working the module beeps instead.
Ian
Acid rush txr6,5.1 surround sound,350 rwkw's,major interior trim work. |
14-02-2011, 09:55 AM | #24 | ||
Sounds like fuel ... seeing as UK is on LPG ... and barely uses petrol anyway ... he's probably not used to the DTE warning for petrol ... hee hee
14-02-2011, 06:19 PM | #25 | |||
UK
14-02-2011, 06:24 PM | #26 | |||
It's a bit like that. I have half the distance to drive to work now ... and it takes just as long as it used to.
14-02-2011, 07:54 PM | #27 | ||
I thought DTE was only 9 beeps? Hmm maybe I will check when I get low on fuel this week.
My XR also beeps for seatbelt.
AU111 XR6 Ute, VCT, Leather, Manual. |
15-02-2011, 07:26 PM | #28 | |||
All Bran = Regular Member
16-02-2011, 08:44 PM | #29 | ||
Audi S3
yeah i drove my AU the other day. then ran out of fuel. Shouldn't have ignored the "3 beeps" HA HA
17-02-2011, 12:26 AM | #30 | |||
meh.
UK, go out and look for the airbag light, if there is no light, start the car and see if the beeping starts a little bit after you start it.. or check the fuse for the airbag
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
