![]() Join Date: Nov 2008
I posted this in the Tech section a couple of weeks ago - without response:
Can anyone tell me how to go about removing the Heater Fan control Knob on a AUIII XR8. The knob I have to replace it with has a lip on the end that will seem to lock into place when installed. My problem is removing the old one to replace it with the new one. Do I need to remove the trim panels around the radio/ Heater controls to do this?
MY18 Mustang GT MY18 Everest Trend Harley Davidson FXBRS |
#2 | |||
not here much anymore
headunit out find all philips head screws in dash and undo then pull the fascia off the heater controls then screw into that from the back so you can undo those screws, and then access the knobs.
RAM 1500
#3 | |||
I guess Ill set aside a couple of hours to do it ![]()
With da Warlords
^^^ As he said. Just be careful when pulling the fascia off, that you don't break any of the clips (or bloody cut yourself on the sharp edge like i do lol)
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
#5 | |||
It is fairly straight forward after that, I cant remember the location of all of the screws once you get the HU out but just have a good look around and you will find them. After that you should be able to firmly pull off the outer surround and access the AC controls, you will likely need to unplug all the looms etc to be able to take it out and work on it. Dont worry about that bit though because all of the plugs are different, so you cant plug them into the wrong spot (different sizes etc).
RAM 1500
#6 | |||
RAM 1500
