15-01-2011, 12:01 AM | #1 | ||
Hey guys,does anybody else have issues with their cars running crap while driving in the rain?
I have 2 AU 2 utes(ded gas)and they both do it. While coasting at a certain speed it loses power and i sometimes need to gear down or if i take my foot off for a second and back on again its come good for a few more seconds only. Any ideas? |
15-01-2011, 12:20 AM | #2 | ||
Does it only do it when its hot or cold as well ?
The air pipe that goes from the snorkel to the converter, Is it getting water down it ?
AU XLS. |
16-01-2011, 07:42 PM | #3 | ||
Do you nean hot weather of if the cars temp?
As for the pipe i will check it out.Nice day today and i had no issues. |
16-01-2011, 08:51 PM | #4 | ||
Next upgraded Mk1 Leopard
Put them back on gas
UK
16-01-2011, 09:03 PM | #5 | ||
Cars temp.
AU XLS. |
17-01-2011, 11:37 PM | #6 | ||
The 6 cyl AUs ignition coil pack is positioned right down low in the engine compartment, right down on the front crossmember, left side, below the induction stuff.
I'm thinking these may be getting wet, and maybe the water seals are not properly positioned, hence the bad wet running...just a thought! This is the best reason I can think of for not driving thru water any more than, say, about 100mm deep, and very slowly, for everyone's benefit! 4ford |
17-01-2011, 11:42 PM | #7 | |||
rexnet
spot on. if i drive around and go thru a puddle thats to deep (which i try to avoid alot!!) my car starts to miss and sound like a WRX. after a while it dries out. |
18-01-2011, 01:28 AM | #8 | |||
18-01-2011, 01:35 AM | #9 | |||
18-01-2011, 01:35 AM | #10 | ||
had similar syptoms in an xh, fine crack in the coil casing, wouldnt kill it, just made it cough for a bit each time it splashed.
18-01-2011, 01:37 AM | #11 | |||
18-01-2011, 01:42 AM | #12 | ||
The auto one has had coil pac and leads recently replaced(last year) and i hanvt had the manual one for all that long so im not sure if it has the original leads.
I was thinking coil pac so when i get the chance i will look at some connections. As for puddles,i dont think its an issue.The day it got really bad it was very wet and the roads were soaked but i didnt go through big puddles.Thats what i have lifted Patrol for. |
18-01-2011, 02:32 PM | #13 | ||
ROCKING THE EL FUTURA
it just doesent like wet days mate.
weird mine will do the same but its petrol only and going through big puddles which indicates the coil pack.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
18-01-2011, 02:49 PM | #14 | |||
18-01-2011, 06:11 PM | #15 | |||
rexnet
18-01-2011, 06:16 PM | #16 | |||
rexnet
90% sure its coil pack related |
18-01-2011, 06:36 PM | #17 | ||
Au Falcon = Mr Reliable
G'day all, yeah ive had the same issues in my au 1 futura (petrol only) and i reckon the problem is the loom connecter to the coil and the four connecter pins in the coil connection. The seal there is not very good- once the pins get wet a couple times the connecter pins start oxidising and go green. The fix i did was to clean both the pins and loom connecter (scrape the green crap off or use contact cleaner), spray both sides with a heap of wd40 or crc, refit connecter to the coil and tape up the connection with plumbers tape or if you want to get fancy fabricate a water deflector to deflect water away from the coil. Since i did the fix i havent had the problems with the engine missing and carrying on in the wet but i still try to avoid the big puddles!
cheers Maka |
18-01-2011, 11:25 PM | #18 | ||
Thanks guys,have been a great help.
