Old 05-07-2010, 11:35 AM   #31
TheInterceptor
Cruising...
TheInterceptor's Avatar
Originally Posted by Auturbo6
The gear gates (3-2-1) are designed for exactly what u are using them for. Just don't abuse them. The more the gearbox shifts the shorter it's life. Reguarding low (1st) when selecting low the gearbox applies the rear band, that's why harsh engagement, the rear band is only used for reverse usually. When in drive wilst in first at lights, the rear band is not on, but the one way clutch, the rear band is only on in low. Same goes for selecting neutral at lights. Great way to put unessasary pressure and wear on the front clutch when engaging drive again. So leave in drive at all times and let the converter do it's work. Also don't stall the car up, overheats the oil in the converter and substancially reduces the oil life, therfore also the transmission life. Some useless facts for a sunday night. Later.................
thats good to know thanks mate
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2010, 02:13 PM   #32
Stattic
Stattic's Avatar
Well thanks guy I often go in neutral at lights because I have stalling issues I'll have to sort it out soon lol retune!
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
