as the title suggest will the ecu run a stroker motor. im considering stroking my 220kw engine
![]() Join Date: Dec 2004
Edit it Josh
Yes it will run it but to optimise it you will need to tune it.
not here much anymore
Mine had enough trouble running a bigger cam, I wouldnt try it on a 347
RAM 1500
ok i would get an edit but im in a country town and there is no tuners around so it makes it a bit hard. just wanted to know if it would be safe or could even drive 400km
The engine size upgrade wont affect it, its the cam depending on how big you go that the ECU will struggle to handle.
#7 | |||
RAM 1500
It will run it OK with an edit (flash tuner). Just remember the standard 220 settings may be very lean with the stroker motor so no full throttle load until you can get it to a tuner and have the edit box tuned. Drive it the absolute minimum distance possible until you can get it tuned.
#9 | |||
Back to Le Frenchy
It will be very lean and idle like a cow, mine was near on undriveable with the factory settings.
I miss my wheelbarrow
![]() Join Date: Jan 2005
Everyone gives a different report on what will and wont run.
STROPP still has an AU XR8 pcm, (with the XR8 file) in his T3 TE50 after it crapped itself on the nullabor. It runs as strong as any of them and has given no sign of having issue. Peeler has a centrifugal blower on his P250 with the standard T3 pcm file, and has run like that for longer than I have known him. So it really does seem almost like pot luck, as I know what a heavily cammed 5.0L will run like unedited, but that is mostly base idle speed that makes it a pig. The biggest thing is that the Maf and the injectors are matched to each other, and that the injectors are matched to the factory pcm tune. Daniel |
#11 | |||
With an XR8 maf no way will it run lean, different if you run a 90mm ford racing maf... |
#12 | |||
Daniel |
#13 | ||
Boost Addict
u can always play with an adjustable FPR as a short term solution till u get it to a tuner
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
#14 | ||
Have the flash tune it especially if ur going to run a bigger cam. Plus is dosent cost much to do a flash tune epecially if your gona build a 347 stroker.
