Thought I'd give the forums a go before I go hunting for some strange electrical issue.
So the faults are, when the brake is applied the parkers come on, also when the car is running and the headlights are on and brakes applied, if you turn the key to off the car continues to run until either the brakes are released or the headlights are turned off. Anyone else had this or a similar issue? |
Is your car's name "Christine"!!!
2006 BF F6 Typhoon (HER F6) 2005 BA F6 Typhoon (HIS F6) |
#3 | |||
Back to Le Frenchy
Do you have trailer plug wiring?
#4 | |||
You have an earthing issue, the brake lights and parkers come on together cause it's pulling earth thru the parkers. just start going around putting some extra earths on, start with battery to car and then battery to engine and go from there, after that go down back of car and add one to the earth point for tailiights to the body.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
Alright, was just looking in the boot, there isn't a short where the trailer wires were connected. While I was there I notice an amp had vibrated a bit loose so I got the screw driver out and tightened it up, while doing so the car locked it self, has me wondering could the other issues be a fault with the BEM?
Or did you just unlock the car without opening the doors so therefore it did its auto relock thing it does?
As for bem causing these issues, very slight possibilty, but as i said before, its a known earthing issue that causes the symptoms your talking about.
Sales Representative
The only common thing i can think of is to do with the Ignition line itself... and whats connected to it...
Ok so the other day I made up a few jumper leads for earths, did not fix the issues.
After a bit of thought I have come to the conclusion it must be the BCM as this is the only common point for all 3 - brake lights parkers and ignition. Will book it into ford next week for a new onw unless someone can suggest a fix, which I don't think exists. |
try pulling the BEM fuse no10 out ( fuse box inside car) for 5mins and see if its makes any differance.....
cheers, will try now
#12 | ||
Gave it a go, no joy. I started pulling the boot to bits and found the problem to be in the drivers side tail light, I don't know what the issue is yet but with the pasanger side tail light disconected the faults are still there, with only the drivers side tail disconnected it disapears. Might just be a bit of crap on the lamp holder, I just don't understand how a short with the brake lights and parkers can give power to the ignition. Whoops I think I just gave a tip away to anyone looking to pinch an AU
#13 | |||
Blown 5L coming
could be slight corrosion in contacts is causing earthing issue...been known to happen, weird how it effects engine run on though....thast got me completly stumped
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
#14 | |||
#15 | ||
Thats what i was talking about with earthing issue, i believe what happens is the earth point at the tail light also supplies earth to other parts of the car, therefore when its missing or not good enough it pulls power from other sections switching odd things like the ignition on, the thing is i know about it, but i don't know what wire exactly or anything it is, i just know that there is an earthing issue to do with the tail lights that causes this type of issue, and it happens on nearly every car/make out there, just that it causes different symptoms in different cars.
ever noticed a commodore driving around with an indicator that lights up when they brake?
#16 | |||
Miami Pilot
![]() Join Date: Jan 2005
#17 | |||
Either way I found the issue, the two filaments in the brake/tail lamp globe were touching. |
#18 | ||
In the globe itself.... who would have thunk it... good to know you found it...
#19 | |||
Falcon Unbelievable!
and "You keep a knockin' ... but ya cant come in" plays on the radio at full bore. muhahahaha on a serious note, thats some nasty stuff amigo good luck. |
