#31 | ||
Smile
Hahah..yep I think someone posted the answer several times above
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#32 | ||
AU00
If it was the pump why would it cause the Squeal?? The Squeal can be narrowed down to the front part of the motor. I am all for changing the pump i've seen a nice Holley high output one the thing that is stopping me is the Squeal..
#33 | |||
#34 | ||
Young !@#$ Head
Joe check your cat converter. If its collapsed inside it will block your exaust causing this. Then as the revs pick up so does the pressure then it can free up. My XR8 did it to one cat and the other was fine. Was really wierd. Just a thought. It's not hard to check.
www.aufalcon.com.au/blackauxr8 AU3 220 XR8 CUSTOM PEARL PAINT LOWERED THEN LOWERED EVEN MORE ADVANTI 20's K&N PORTED MANIFOLDS TWIN 2 1/2 into 3 inch PIPES 244rwhp NOW WITH T5 5 SPEED COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL SUZUKI GSX-R 750 BLACK 2007 MODEL CARBON FIBRE YOSHI PIPE |
#35 | ||
Sly like a G6
If your cats are flanged it will cost $0 to unbolt them & look inside. My 6 was flat as a tack to about 3000 then picked up from there to redline before I changed the cat, much better afterwards. About 1/2 the core was in chunks bunched into the back end of the cat.
Have you had a kind of metallic buzz at idle from underneath the car that sounds like the exhaust is loose and vibrating against something solid? Not necessarily now but in the last year or 2? I've had cats collapse in 2 cars so far, and that buzz has been apparent in both around the time low-rev performance went south. But don't let me talk you out of the fuel pump either. I'm just suggesting something that won't cost you to check if you have access to a pair of proper AS-compliant axle stands, or a mate with a hoist. I'm guessing you might need same to change a fuel pump, might as well look at the cats "while you're down there".
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
#36 | ||
AU00
Well it is finally fixed. Yep and just to me off it was a blocked injector. So after 5 mechanics, many new parts and around $2000 dollars it was done by a bottle of Nulon total fuel system cleaner. Yep the grand total of $25. Since then i have had a total fuel system clean and all the injectors replaced. Also had the preasure out of the fuel pump checked and that is okay.
#37 | |||
![]() Join Date: Jan 2005
