Old 17-11-2008, 01:52 PM   #1
Bolly
Bolly's Avatar
Default Jacking the Car
Hi Guys
Is there a problem using a trolly jack directly under the diff centre,The car is a XR8 AU2.......
I looked underneath last night but it was hard to see with the large exhaust pipes being in the way.. Reason of concern is it looks like the Diff centre is be made out of aluminium..
Bolly is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2008, 02:00 PM   #2
RG
Back to Le Frenchy
RG's Avatar
That would be the IRS cradle you are looking at. I've jacked mine up from there before and so have others without any issues.
Personally I prefer to use the jacking points on either side and then axle stands.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2008, 02:32 PM   #3
dreadly
Fine to use the diff
dreadly is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 04:01 AM   #4
Bolly
Bolly's Avatar
Thanks for that guys
Old 18-11-2008, 01:40 PM   #5
waggaclint
waggaclint's Avatar
if its IRS you shouldnt jack on diff as it can put the tailshaft balance out as they are laser balanced....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 01:51 PM   #6
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
I think you mean tailshaft alignment, not balance. The tailshaft is suppost to be align to be perfectly straight at the rear uni. At which being that the diff centre is rubber mounted, i'd have to agree with waggaclint and say that we probably shouldn't be lifting it by the diff centre, although i have many times.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2008, 10:49 PM   #7
T3man
T3man's Avatar
Yeah, just jack under the diff - and then book your car in for diff mounts and tailshaft alignment - which will prolly only cost a few hundred tokens.
OR - you could jack under the designated points and that will cost you ... actually, NOTHING! WOW, that's a bargain!
PS. Up front you could also jack under the alloy crossmember - it's not all that expensive to replace if you crack it - I've seen PLENTY of THESE!!!
Old 18-11-2008, 11:16 PM   #8
Bolly
Bolly's Avatar
Thanks for the that guy`s ..Lucky i asked first before i did any damaged ..
T3man..I was wondering about the alloy Crossmember...I`ll have to get some Ramps..
My trolly jack seems useless on this car..I can`t jack from the side of the car unless i buy another Trolly jack to put on the other side to evenly jack the front or rear of the car..What a hassle.. Should have kept my EB V8.. :-) Just Kidding
Old 18-11-2008, 11:32 PM   #9
T3man
T3man's Avatar
Yes, they are difficult for the home-handyman - and then you should try a T-Series - I have to drive mine onto wooden chocks to get enough ground clearance for the floor jack to even slide under the sills to reach the jacking points. I have seen heaps of AUs (and B Series) damaged by incorrect jacking. Some people get away with it some of the time, but if you're an unlucky sod like me it only takes one "bad" decision to cost you a heap of grief ... AND DOLLARS!
Old 18-11-2008, 11:41 PM   #10
dreadly
Sorry didnt know about irs... mines a ute ;)
