04-06-2008, 09:17 AM | #1 | |||
JMM modded EF
people i own an ef and am putting au injectors into it. is there only one type of injector i can use (i think theyre blue?) or are theyre higher performance ones as well?
"She goes like a zirtek" WANT A FAST FORD RING THIS BLOKE V V Abbott Engines for HeadWork 20 years experience PH Rob on (07) 5526 3883
05-06-2008, 01:25 PM | #2 | ||
With da Warlords
Blue topped Au injectors are 24lb AFAIK. And yes you can get bigger ones than that.
The question has got to be asked though? Why are you changing them? You will not see a lick of difference unless your leaning out in the high rpm's, something that is not likely unless your car is F/I or heavily modified / stroked etc
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
