I've just changed the front discs on my AUII ute - set of new RDA standard rotor and new pads. Drives fine, stops fine, but I've noticed on one of the rotors a dark mark running the outer half of the disc all the way around. I spoke with someone yesterday and they said it was probably the anti-rust "oil" used on the disc. I did spend some time cleaning the disc with thinners before installing them, but obviously I couldn't get in the disc fins and whatnot.
Do I need to worry about this dark patch, or will it just eventually wear off? (I can't seem to rub it off with thinners or anything?) |
Critical Thinker
keep an eye on it. should the braking of the car diminish in quality, i could be a hot spot on the rotor. Dont quote me on this though. Without any pics its hard to give an opinion.
But I recommend just keeping a close eye on it.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
#3 | |||
.. also it runs around the whole edge of the rotor (about 1" down, all the way around). I'll see if I can get photos .. Rod. |
Critical Thinker
Just a quick question Rod, did you bed the pads in at all, or just drove on them once fitted?
