Old 26-04-2008, 02:17 PM   #1
Keepleft
Mot Adv-NSW
Keepleft's Avatar
Default Future of 400Mhz - UHF CB - planning underway.
Knowing that some here use UHF CB on the road, those of you technical might find this of interest.
400Mhz, future of UHF CB et al
Discussion:-
http://www.austech.info/communicatio...html#post40513
See Page 36 of the Pdf download re 12.5Khz channel spacing, see link within.
http://www.acma.gov.au/WEB/STANDARD/pc=PC_311117
The closing date for submissions is 18 July 2008.
J.
ORDER FORD AUSTRALIA PART NO: AM6U7J19G329AA. This is a European-UN/AS3790B Spec safety-warning triangle used to give advanced warning to approaching traffic of a vehicle breakdown, or crash scene (to prevent secondary). Stow in the boot area. See your Ford dealer for this $35.95 safety item & when you buy a new Ford, please insist on it! See Page 83, part 4.4.1 http://www.transport.wa.gov.au/media...eSafePart4.pdf
Keepleft is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2008, 07:20 PM   #2
flappist
In answer to your questions over there:
1) 12.5Khz is not a problem provided there is an offset, maybe 5 or the defacto standard 9Mhz for TTR activity. The current 750Khz offset makes it difficult and expensive to maintain isolation.
2) Analog FM should not be replaced by digital as it will reduce range, make incumbent equipment and systems redundant and inflate CPE prices.
3) 25w over 5w is only 7db but increases the RF current to a level where users who misoperate their equipment could cause injury or death. The increase in range is insignificant. Also on existing TTR it would require another 7db of isolation which would
result in at least 1.5-2db insertion loss.
But of course it is the government so it will be a clusterflug........
flappist is offline   Reply With Quote Multi-Quote with this Post
