Old 14-01-2008, 04:05 PM   #1
alkybrown
alkybrown's Avatar
Default 5 speed in mk2 escort
i hav a 80 escort sport 1600 need to know what i need to do to put a 5 speed cortina gearbox in to it? any help would be appreciated.
alkybrown is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2008, 06:49 PM   #2
Sterling
i heard that the shifter will be a bit further back, but the bell housing matches the engine. not sure about transmission mount.
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2008, 08:38 PM   #3
krt10
eskyman
krt10's Avatar
im pretty sure that your escort has a manual gearbox tunnel you will need to do some cutting and welding to fit it in. 5 speeds fit well into an auto tunnel.
who says kents cant be quick
krt10 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2008, 04:59 PM   #4
alkybrown
alkybrown's Avatar
thanks for yor help
Old 15-01-2008, 09:55 PM   #5
eski666
eski666's Avatar
I didnt think the cortina came out with a 5 speed?
New engine on the way :
Weisco Pistons, Total Seal rings, Crower rods, BIG lumpy stick, TO4E with back cut exhaust wheel 1.0 rear housing 30psi!!, major head modification! Bring on the 1/4 mile :
eski666 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2008, 08:06 AM   #6
whooligan
whooligan's Avatar
Correct.
I think he means a Sierra 5-speed.
Gear lever sits a few inches further back and gearbox mounts need modification. Not exactly rocket-science.
Old 16-01-2008, 07:57 PM   #7
thisisxhcountry
thisisxhcountry's Avatar
out of curiosity what is the best 5-speed for the mkII esky? is it the one out the sierra?
Don't P*ss Me Off, I'm Running Out Of Places To Hide The Bodies!!! :
thisisxhcountry is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2008, 08:15 PM   #8
mk2_1979_escort
Depends what you mean by "best". Some common upgrades include a celica/supra 5 speed box which have higher gear ratios than the sierra 5-speed and escort 4-speed, but you are required to get a different bellhousing for it to match the escort. Otherwise the sierra 5-speed is just a escort/cortina 4-speed with an over-drive ( or an extra gear ) as the first 4 gears are the same ratio. However many people prefer the 4speed as it is much stronger than the 5 speed and are much easier and cheaper to source.
hope this helps.
please correct me if im wrong guys
mk2_1979_escort is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2008, 10:17 PM   #9
thisisxhcountry
ok thanks!!!
