HSV, I just ate one
Whos going to Whoop *** Wednesday this Wednesday (09/01/08) ?
I will be there in my BF XR8 (DVSLYQUIK) Hopefully making a 13.3 pass ![]() |
JimmysAUXR6
yeah i might go give mine a blast just see what time i finish work
HSV, I just ate one
I took the day off work
![]() So can get it serviced in morning and get it washed around lunch time then lose a little weight like the spare wheel and some i got in boot and back seat and be ready for hunting more 13.3's ![]() |
HSV, I just ate one
OMG Today sucked *** !!!! think it was the warmer temp and very high humidity ! i couldnt get lower then a 13.6 by memory GRRRRR
Was expecting at least 1 run at 13.3 :( |
#5 | |||
I have trouble getting traction at the track in my XR8 so I'm a little curious about your setup. Cheers. |
i'l give you a tip - dont lower the psi on low profile tires
it does next to nothing. a low profile tire will peform at its best when at the reccomended psi
05 BA II Pursuit Ute # 147 in RAPID 20" incubus rims 6 speed manual BLUEPOWER CAI twin 2.5" catback more to come ![]() |
#7 | |||
Cheers |
HSV, I just ate one
I used to have Dunlop SP9000's but got new tyres on the back.....
I belive lowering the pressure in my tyres does help but it is fairly over rated it doesnt make a huge difference its only slightly better or so i have found.... When i was there couple months ago i was running with normal pressure, getting constant 13.6's then dropped to 19psi and started getting constant 13.5's Was about 0.06 second difference i was averaging between standard pressure to dropping the pressure to 19psi.... so not huge but it is something. its that small of a benefit it probably not worth the extra damage you do to your tyres and iv been told it also puts more strain on your driveline..... So yes 3 would be right in saying theres no point, but if your after that tiny drop off your time then id say give it a go.... Im half ****ed writting this so im sorry if it doesnt make sense lol :P |
#9 | |||
