Is there any requirement to bleed air from the cooling system when changing coolant?
If so, where are the bleed points? |
Over Thinker
you can squeeze the top and bottom radiator hoses to expell air
turn heater on check level after the thermostat has opened on other cars if the temp sender was at the top of the inlet manifold you could undo it
My car goes Brumm Brumm |
