Hey,
having trouble with my gfs car, KJ laser, the brake light globes are stuffed and need to replace them, Im guessing you undo the two screws and they should pop off however ive hit a problem, they dont pop off. is there a trick to it or something? Cheers in advance, ive looked all over the net Michael |
Over Thinker
just a guess
the screws just hold the lense in place and the bulbs are replaced from the back of the lense assembly lense may have been siliconed in to stop the water one type with care are ther little plastic tags holding the bulb electricals to the back of the lenses in the boot section
My car goes Brumm Brumm |
Giddy up.
There is two screws you need to take out, you can see them once you open the hatch, then all you need to do is pull the whole brake assembly straight out, it will be tight because they slot into a sleeve, you will see this as you take it out, but don't be affraid to pull it hard, as you need to.
