Old 23-07-2007, 08:06 PM   #1
347_XR8
Slide Baby Slide
347_XR8's Avatar
Default Boosted E-series with stock ECU
What are people pushing with boosted e-series with a stock ECU? I ask this because at the R31 dyno day last week there was a turbo EB that ran 196rwkw!
Didnt even reach peak power due to it leaning out to much with a AFR of 15:1. Was a fairly stock engine running an extra 2 RB30 injectors as far as i know
What else are people running with stock ECu's?
:the_finge You want more inches...........STROKE IT!!! :the_finge
Mr Super Skid-Man
347_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2007, 08:11 PM   #2
JD86
DELANY
JD86's Avatar
gee thats pretty impressive with stock ecu. do you know how many pound it was on?
2010 FG XR6T - 6 speed manual - luxury pack
JD86 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2007, 08:16 PM   #3
347_XR8
Slide Baby Slide
347_XR8's Avatar
7psi...but i think there was a boost leak or something wrong with the waste-gate
Mr Super Skid-Man
Old 23-07-2007, 08:22 PM   #4
AUTickford
XD197
AUTickford's Avatar
STOCK? r u sure? People will say anything at dyno comps to play down just how much money they waste on their cars!
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2007, 09:04 PM   #5
LTDHO
The one and only
LTDHO's Avatar
snypereb is running stick ECU
I have seen a stock ECU boosted E-series pass 200rwkw.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2007, 09:07 PM   #6
347_XR8
Slide Baby Slide
347_XR8's Avatar
I'm sure. I've talked to this guy before a few times.
Mr Super Skid-Man
Old 23-07-2007, 10:28 PM   #7
Mr. CVE
If it aint Blown it Sucks
Mr. CVE's Avatar
Snort Performance and myself CVE got a standard EA Falcon 5 speed from the wreckers.
We fitted a stage 3 kit to it. apart from the turbo kit is was completely stock, stock pump, injectors, ecu etc.
It did have a 3" exhaust on it.
The wastegate was set at 9 psi.
all we did was turn the dissy back a little bit and fit an adjustable fmu after the main fuel reg.
We ran the car up and it made a constant 205 rwkw.
after that it was starting to lean out a abit, which you would expect from a stock 300,000km old fuel pump.
We drove this car around heaps and thrashed the crap out of it, untill it leaked water, so we quit on it as we thought we did a head gasket, turned out it was the heater tap !!
So it is still going !!
I would reccomend a bigger inline pump, but it can be done on a std ecu. Yes better results will probably come from an aftermarket ecu and tune but that is big $$ for some people.
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph
@235 rwkw !!
Now turbo 11.77 @114 mph
320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds:
Now for sale
http://www.fordforums.com.au/showthread.php?t=11296772
Thanks to Snort Performance, Headsex and CVE
Street car DeTomaso Pantera
Drag car 1995 Mustang, Haleys Comet ( It's back !)
Power by CVE
Melbourne's first SNIPER Tuner :
Now tuning E series
Mr. CVE is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2007, 10:37 PM   #8
fritzz
fritzz's Avatar
i ran my car with all stock gear and a 2:1 fuel reg. pulled bak the timing a couple deg's. ran it on 6psi. never dynoed it but it managed a 13.8 @ 105mph with the stock open center diff and 3.08 gears. no traction
# 1997 EL Falcon GLI - Custom built AU 4L bottom end, Billet Turbos B76-GTS, Nizpro plenum, 6boost manifold, Autronic SM4, Custom billet surecam camshaft, 3x 044 pumps and custom undercar surge tank, Custom 4" exhaust, ID2000 Injectors, 60mm Turbosmart gate, Turbosmart race port bov, , Tremec TKO 600, Cebco 330mm Brakes, 3.7:1 9" diff with billet axles and trutrack center 608rwkw, 9.6sec 1/4mile
# 2008 FPV FG GTE - Xa Coilovers, 20x8.5/ 20x10 fairladys
fritzz is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2007, 02:09 PM   #9
3.9from hell
hoons cause global warmin
i notice there are a few non intercooled kits for e series getting around, anyone got any experience with such a set up?
3.9from hell is offline   Reply With Quote Multi-Quote with this Post
