18-03-2007, 09:49 PM | #1 | ||
I'm thinking of starting a new project and am thinking of building a coupe or mid 70's ute as i have always tinkered with late model efi fords i never really worried about having a carb with no pollution gear attached some of my mates have advised me it's a $5000 fine for having a holley on an xc-xd as they came out with pollution gear so which year did that it start and can someone advise me on the legalities of running efi on an 351 in an xb for example.
thanks for the help guys |
18-03-2007, 09:54 PM | #2 | ||
1976 I believe
18-03-2007, 10:35 PM | #3 | ||
Has anyone been fined for having a Holley on An XC-XD? No, I don't know of anyone either.
18-03-2007, 10:41 PM | #4 | |||
18-03-2007, 10:44 PM | #5 | ||
Wirlankarra yanama
ADR27A... Australia's contribution to saving the planet lol !
I think it was 1975 that alot of crap to hit the fan and people predicting the end of petrol-loving-V8's... |
18-03-2007, 10:51 PM | #6 | ||
rocknrolla
most lpg places wont put gas on a thermoquad carb as it has a plastic bowl, the suggested carb is a holley...
1979 P6 LTD 383c
1970 ZC Fairlane 500 351w 1964 XM Falcon Deluxe 200ci |
18-03-2007, 11:05 PM | #7 | |||
ADR 27A actually made a motor use MORE fuel, but it gave less pollution. With Holleys you get more points if you have an electric choke (at least in the States you do, cause it turns itself off). http://www.holley.com/emission.asp My auto choke 750 gets a blue star. Manual choke 3310 only gets an amber. |
18-03-2007, 11:05 PM | #8 | |||
rocknrolla
1979 P6 LTD 383c
18-03-2007, 11:08 PM | #9 | |||
rocknrolla
1979 P6 LTD 383c
19-03-2007, 02:12 AM | #10 | ||
Have modded 2 Celicas when I was young and didn't know better.
One was a 1976 RA23, and that had 27A stamped on the compliance plate. The other was a 1975 TA23 and it was 27 only (no A). Therefore either late '75 or early '76 was when the big hit on pollution came in. |
20-03-2007, 12:59 AM | #11 | |||
BTW none of theese cars run lpg and i'm not planning running lpg either i want a hi=comp clevo in an xe and all this pollution crap is putting me off. |
20-03-2007, 01:40 AM | #12 | ||
What's green is gold
I have a 650 holley on my cleveland, and Vic roads passed it sweet, it has all of the same Vac lines, so i dont see the problem... Plus the thermo-quad was a heap of shiite..
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
20-03-2007, 09:43 AM | #13 | ||
hmm eyebrows
Came in July '76. Co-incided with Ford releasing a modified 1600 engine in the Escort range that was a pure choker as opposed to the pre '76 1600 fitted in the new MK2 Escort Ghia. Sorry but thats the way I remember as I used to tinker with these during my boyhood.
1999 Range Rover 4.6 V8. Soon to have a new blue oval bent eight. |
20-03-2007, 10:02 AM | #14 | ||
Discovery 4
I worked at a Holden dealer in 76 when 27a was introduced. 202's had a bad habit of burning valves because of 27a. The fix after fitting new valves and seats was to not fit valve guide seals the oil flow down the valves cooled them. But my guess is it ruined any gains made by 27a. ADR 27a was a dark time in Australian automotive history.
### Blue Ranger Wildtrak V6 on the way. Factory Canopy & 140l ARB fuel tank. Discovery 4 3.0 TDV6 SE. Long range aux tank, Kaymar Rear Bar, 18" Off Road rims. Lotus Trooper. Mini Inspired by Goodwood. |
20-03-2007, 10:14 AM | #15 | |||
21-03-2007, 12:02 PM | #16 | ||
Thanks guys i'm not so worriesd now that so many people are saying they don't get picked up well i tracked down a cheap xe esp going to look at it today if its half decent the fun starts
21-03-2007, 01:21 PM | #17 | ||
Cam Luncheon
Thermoquads became bad news when they first started to burn the cars to the ground.
I have personaly had a friends car get turned to charcaol because the plastic bowl split causing an unstoppable flow of gas, which gets ignited and can only be stopped by turning the valve off at the tank. Not that your really thinking about that when the whole front end of your car is on fire :
-- Any problem is best approached sideways ... with a crowbar --
-Mental on Life, the Universe and Everything. |
