Old 24-01-2007, 06:27 PM   #1
Jorgo85
Jorgo85's Avatar
Default Head Gaskets
My XR6 is starting to show symptoms of a rooted head gasket. Coolant is coming out between the head and the block behind the exhaust manifold. Just wondering if when I replace it, would there be any advantages of putting an AU XR gasket in for example. Which model had the best quality standard gaskets? And are they interchangable?
Jorgo85 is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 06:31 PM   #2
Grechie
Grechie's Avatar
yep, put a AU headgasket on, i did, it fits no problems, and it even raises compression a little bit!
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 06:44 PM   #3
5speedeb
now with 3.73 lsd
au gasket gets my vote
g6e turbo
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 07:09 PM   #4
Jorgo85
Jorgo85's Avatar
Are the gaskets the same for each series, or is there a particular one to get?
Old 24-01-2007, 07:30 PM   #5
Blue Ice
Living the Dream
Blue Ice's Avatar
AU gasket, it should outlast the life of the car.
Blue Ice is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 08:31 PM   #6
10secondET
one day
10secondET's Avatar
au gaskets are the go there really just a shim
XY GTHO MOCK
406 cleveland grout filled, pavtek alloy girdle
scat 4340 crank, scat h beam rods 2000 series bolts
CHI cnc 2v heads
comp 308r solid roller camshaft
torque power single plane manifold
950 quickfuel race carb
pro trans c10 with transbrake
5500 tce converter
3.89 diff gears
10secondET is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 08:32 PM   #7
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
AU seems to be the way to go. But to all out their that have used one, what head bolts do/should you use? and what torque do you take them up to?
pete j
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 08:33 PM   #8
EB Pete
EB Pete's Avatar
AU multi-layered seems to be the way to go. But to all out their that have used one, what head bolts do/should you use? and what torque do you take them up to?
pete j
Old 24-01-2007, 08:37 PM   #9
10secondET
one day
10secondET's Avatar
i use new bolts as the old ones fatigue and twist
XY GTHO MOCK
CHI cnc 2v heads
5500 tce converter
3.89 diff gears
Old 25-01-2007, 01:34 AM   #10
chrisbee9494
what does the head job cost? and when do you know that you gotta go for the full go.
chrisbee9494 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 01:39 AM   #11
opto
This is open to two interpretations, I find one of them very funny. Think about it. :
Originally Posted by XCPWSF
Is there portable speed cameras? Because coming home from school I noticed a cop sitting on the corner, with some box with buttons and knobs, with wires running into one of the big gum trees.
Just practicing with the Tazer on a Koala?
opto is offline   Reply With Quote Multi-Quote with this Post
